3.1 & 3.2 Extensions Database 3.1 / 3.2Social Buttons
AtillaBlack
Re: Social Buttons
Post by AtillaBlack »
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/systeminfo/event/listener.php on line 44: shell_exec() has been disabled for security reasons
Any solution ?
admin1
    Android Firefox
Re: Social Buttons
Post by admin1 »
How can I align social buttons on the left or center side of the header ?
Or at the footer of the index ?
Re: Social Buttons
Harrison76
Re: Social Buttons
Post by Harrison76 »
Hello, is it compatible with 3.3.10? is it possible to add other social, such as telegram, linkedin, tumblr, youtube?
thanks
Harrison76
Re: Social Buttons
Good morning,
I loaded the plugin as you indicated, I activated it from the customization items but it doesn't appear in the extension items. what is it and how can it be fixed?
phpbb version 3.3.10
Thank you
Re: Social Buttons
Tested and i see works fine
Harrison76
Re: Social Buttons
Unfortunately I confirm that instead it does not appear among the extensions and does not work, despite being activated. I attach screenshots
Re: Social Buttons
Just installed this on phpbb 3.3.10 and is working fine.
Re: Social Buttons
Harrison76 wrote: 08 May 2023, 11:00 unfortunately I confirm that instead it does not appear among the extensions and does not work, despite being activated. I attach screenshots
Did you clear the cache, I forget to do that sometimes myself....
Harrison76
Re: Social Buttons
Yes, I deleted it but nothing changed
Re: Social Buttons
Harrison76 wrote: 06 May 2023, 08:13 Good morning,
Thank you
This can happen due to a conflict with another extension (DEV or BETA) installed on your forum. If you have the option to disable all extensions and test only the Social Buttons extension, do it.
phpBB: 3.3.15 | PHP: 8.5
Re: Social Buttons
You prob have another ext using the required event it can only be pulled so many times. Looking at your image you not using the event for any thing else.
DW Adams
Re: Social Buttons
Post by DW Adams »
Ok, so I'm trying to add Bluesky to this ext.
What I'd like to do is replace GooglePlus with Bluesky.
Easy enough in Language, but I'm still needing an icon to replace GooglePlus.
I was using icons from Font Awesome in the Footer Icons extension. But yours place them at the top of the page where they're seen better.
Am I able to add the icon or do I need to wait for another update?
DW Adams
Re: Social Buttons
Post by DW Adams »
BTW, I using
phpBB 3.3.14
Social Buttons 1.0.1
