3.2 & 3.3 Extensions Database 3.2 / 3.3Download System
Re: Download System
Try to change the prosilver folder to bootlike and see if it works.
asouza
Re: Download System
Post by asouza »
Wow!!!! Thank you very mush, it works! good! :thumbup:
Now it just need leave with the same width of style, do you can indicate where I can adjust it?
:tumbsyes:
Re: Download System
You have to check this with your style, it use forabg forumbg-table
bungle000
Re: Download System
Post by bungle000 »
Not a major issue but something that is bugging me to find. How do i remove the arrow next to Downloads in the menu. I have looked in css and tried to find it in the other files and I am either blind or dumb lol.
Thank you
Re: Download System
bungle000 wrote: 17 May 2016, 00:26 not a major issue but something that is bugging me to find. How do i remove the arrow next to Downloads in the menu. I have looked in css and tried to find it in the other files and I am either blind or dumb lol.
Thank you
Open overall_header_navigation_append.html
<li class="small-icon icon-download"><a href="{U_DM_EDS}" title="{L_DM_EDS}">{L_DM_EDS}</a></li>
<li><a href="{U_DM_EDS}" title="{L_DM_EDS}">{L_DM_EDS}</a></li>
bungle000
Re: Download System
Post by bungle000 »
DMZX as always, Thank you
And how did i not see that. It appears that I am both dumb and blind.
Re: Download System
bungle000 wrote: 17 May 2016, 00:30 DMZX as always, Thank you
Bouncer_X
Re: Download System
Post by Bouncer_X »
Hello!
Download fails rather quickly, it is a large file of 426 mb. Is there a size quota I must edit?
Wasn't able to upload it using phpbb, it cited a size restriction around 35 mb, so I uploaded to the category folder using ftp, then imported to db by using phpbb ext menu and entered the directory path, so yes it shows in the download list and it begins download normally, then after 3-5 minutes it will fail.
Edit* To elaborate, it says "The maximum size of the file, which is allowed by your hoster, is 32 MB!" on the New download configuration menu under Extensions tab. Is this possibly the cause of failed download? I can download the entire file using a file manager so it has to be a setting in phpbb somewhere...
How does it know it's a 32mn limit and how can I edit that?
ps. Thanks for the great extension!
Re: Download System
Bouncer_X wrote: 09 Jun 2016, 14:59 How does it know it's a 32mn limit and how can I edit that?
Its in your PHP.ini settings from your host. (beware some hosts will upload big files)
You can also set the timeout higher.
Bouncer_X
Re: Download System
Post by Bouncer_X »
dmzx wrote: 09 Jun 2016, 18:16
Thank you for the quick and helpful response!
Ended up overwriting the php.ini for memory, post and upload max then restarted php.
Now the limits of 500mb for the file size even shows in the Manage Downloads ACP, however it still fails around 20 mb.
When I run a straight http link to the file, the download doesn't fail. Too bad I need to have an entirely different page for the http download, maybe if I could link that url to the "Download" button as a hack.. Think it's worth trying?
Re: Download System
It could be that you host does not allow it then, more then 20Mb.
What you can try is upload a small file with the name, go to that directory in the extension folder.
Then replace it with the same name but the bigger file, to test.
origon
Re: Download System
Post by origon »
How about a higher session time?
I have a test server where the sessin time is set to 72000 and i can download files with a size over 700 mb
Re: Download System
origon wrote: 09 Jun 2016, 20:48 How about a higher session time?
Is that test server local?
It looks like your host does not allow it, maybe check it out.
origon
Re: Download System
Post by origon »
The test server are standing here at home, i am trying to get a real server to host my site, the session settings you have to set that high when you have arcade installed, i have dowmload system installed on another site hosted on Surftown, i will test it there.
Re: Download System
origon wrote: 09 Jun 2016, 21:20 The test server are standing here at home, i am trying to get a real server to host my site, the session settings you have to set that high when you have arcade installed, i have dowmload system installed on another site hosted on Surftown, i will test it there.
Ok let me know the results :wink:
