seacoast
Re: Youtube Videos Gallery
Post by seacoast »
Sniper_E wrote: 06 Apr 2020, 23:52
seacoast wrote: 06 Apr 2020, 03:30 rry. Not sure how I did that.
I have an idea how you did that.... :lol:
:rolling:
TrekRed
Post by TrekRed »
Please make the video show in this style, it inherits Prosilver. I believe that such an extension should be compatible with any style! The viewport is just an empty place. Why can't this be fixed? Need this gallery!
Styles: https://www.phpbb.com/customise/db/styl ... ntu_lucid/
Correct the error and I will help the donate!
TrekRed wrote: 09 Apr 2020, 16:36 Please make the video show in this style, it inherits Prosilver. I believe that such an extension should be compatible with any style! The viewport is just an empty place. Why can't this be fixed? Need this gallery!
if it's style issue,please ask author of this style to fix it :thumbup:
No, I just installed video gallery and the Pro_Ubuntu Lucid style. The style is not the problem because it works and shows up fine in the style.
I am having trouble creating an API key so I am not able to test it completely yet.
Make sure you have the correct version installed for your version of phpbb forum.
And create your API key for your site.
Google Public API key:
In order to use Video Gallery, you must create a Google Public API key. Please, visit Setting up API keys to generate the key. If you have trouble to generate your key, read the guide Google Developers Console Help: API keys. Until you set up your key, the gallery will be unavailable.
Exabot
    Mac OS X Firefox
Post by Exabot »
I'm fine too. Only description too bright ...
TrekRed
Post by TrekRed »
The old version did not work. Updated, it worked. As promised, I will help donat. Thanks!
All ext's are based on prosilver but some other styles will grab the css and work but again not all styles do this.
TrekRed
Post by TrekRed »
How to make a title above the picture?
Why don't I receive alerts when adding a comment to the gallery?
Sniper_E wrote: 09 Apr 2020, 23:24 I am having trouble creating an API key so I am not able to test it completely yet.
Sorted.
TrekRed
Post by TrekRed »
Martin. Are there any solutions to the problems described?
Mobile Error.
That looks like your theme is doing it.
TrekRed
Post by TrekRed »
In the mobile version like that!
How to fix?
You cant it's the way its coded for mobile view yes you can move the text right over but then that makes issues for the video box.
TrekRed
Post by TrekRed »
Martin. And notifications about new comments?
It posts in mchat if enabled it is not coded with a notification in it other than mchat.
