3.2 & 3.3 Extensions Database 3.2 / 3.3Ultimate Points Extension
Ghost
Re: Ultimate Points Extension
Post by Ghost »
Miri4ever
Search in: ./ext/dmzx/ultimatepoints/en/common.php
'WARN_MOD_POINTS' => 'Additionally %1$s %2$s has been deducted from %3$s’s account!',
Then build the following
'USER_POINTS' => 'User Points',
	'USER_POINTS_EXPLAIN' => 'Amount of points the user owns.',
	'FORUM_OPTIONS' => 'Forum Points',
	'FORUM_PEREDIT' => 'Points Per Edit',
	'FORUM_PEREDIT_EXPLAIN' => 'Enter here, how much points users will receive for <strong>editing</strong> a post. Please be aware, that they will also receive additional points, which you defined in the advanced points settings.<br />Set to 0 to disable receiving points for this forum.',
	'FORUM_PERPOST' => 'Points Per Post',
	'FORUM_PERPOST_EXPLAIN' => 'Enter here, how much points users will receive for placing <strong>posts (replies)</strong>. Please be aware, that they will also receive additional points, which you defined in the advanced points settings.<br />Set to 0 to disable receiving points for this forum. This way also the advanced points settings are disabled for this forum!',
	'FORUM_PERTOPIC' => 'Points Per Topic',
	'FORUM_PERTOPIC_EXPLAIN' => 'Enter here, how much points users will receive for placing a <strong>new topic</strong>. Please be aware, that they will also receive additional points, which you defined in the advanced points settings.<br />Set to 0 to disable receiving points for this forum. This way also the advanced points settings are disabled for this forum!',
	'FORUM_COST' => 'Points Per Attachment Download',
	'FORUM_COST_EXPLAIN' => 'Enter here, how much points users will have to pay for <strong>downloading an attachment</strong>.<br />Set to 0 to disable this feature.',
	'FORUM_COST_TOPIC' => 'Points to pay for new topic',
	'FORUM_COST_TOPIC_EXPLAIN' => 'Enter here, how much points a user has to pay to start a new topic in this forum.',
	'FORUM_COST_POST' => 'Points to pay for new post',
	'FORUM_COST_POST_EXPLAIN' => 'Enter here, how much points a user has to pay to make a new post in this forum.',
	'FORUM_POINT_SETTINGS' => 'Ultimate Points Settings',
	'FORUM_POINT_SETTINGS_EXPLAIN' => 'Here you can setup, how much points users will gain for placing new topics, new posts (replies) and editing their posts. These settings are on a per forum basis. This way you can make it very detailed, where users will get points and where not.',
	'FORUM_POINT_SETTINGS_UPDATED' => 'Global forum points updated',
	'FORUM_POINT_UPDATE' => 'Update global forum points',
	'FORUM_POINT_UPDATE_CONFIRM' => '<br />Are you sure you want to update all forum points with the given values?<br />This step will overwrite all current settings and cannot made reversible!',
faroud
    Ubuntu Firefox
Post by faroud »
Is that extension already updated
This is not our work
:whistl:
SymoClash
Post by SymoClash »
How they can spend points if there's no shop?
NAPWR
Post by NAPWR »
SymoClash wrote: 13 Sep 2023, 23:33 How they can spend points if there's no shop?
We spend our points currently on Lotto,
and can send a member some points as well. :tumbsyes:
Forum robbers on the other hand,
can steal our cash in hand if we don't bank it first. :yikes:
Be nice to have extra ways to spend points,
but like all programs,
there are more important extensions being worked on. :buigen:
p.s.
I would like an email sent to the member that points are being stolen from. :guns:
Currently disabled. :shoot4:
My name is Dave I, and all things are out there, and we are in here :mml:
faroud
    Ubuntu Firefox
Post by faroud »
Does ultimate points work now?
Or are there any mistakes?
Regards
ditch
Post by ditch »
faroud wrote: 22 Sep 2023, 08:07 Does ultimate points work now?
Regards
works great on 3.3.10
faroud
    Ubuntu Firefox
Post by faroud »
ditch wrote: 22 Sep 2023, 17:31
Regards
thank you yes work now :wink:
miri4ever
Post by miri4ever »
I cannot install on my fresh board. Getting this kind of error:
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/ultimatepoints/migrations/ultimatepoints_install.php on line 379: Undefined variable $config_data
Fatal error: Uncaught phpbb\module\exception\module_exception: CANNOT_REMOVE_MODULE i
I really need this extension up and running.
faroud
    Ubuntu Firefox
Post by faroud »
How high is your PHP set?
faroud
    Ubuntu Firefox
Post by faroud »
miri4ever wrote: 11 Oct 2023, 16:58 I cannot install on my fresh board. Getting this kind of error:
lower your PHP version in your server
faroud
    Linux Firefox
Post by faroud »
There is a problem with removal
of an extension ultimate points
is a mistake
General error
SQL Error [MySQLI]
Unknown column 'U.User_Points' in 'Field List' [1054]
How do you solve this?
Would like to remove it
Regards
PS: dissolved
was an error from JV Points extension :whistl: :wall:
zhangla
Post by zhangla »
Is it possible to add a link to each post, where end users can click on that link and make a donation of points to the author (because end users like that post), and that donation history is kept with the post and displayed on the bottom of the post, something like "xxx awarded 100 points: I really like your point of view"?
I know currently you can make donation of points to any user, but that donation history is not kept with any topic or posts.
limp8976
Post by limp8976 »
Is there a way to block a link and then unblock it with points? :eyes2:
ramboagent
    Windows 10 Edge
Post by ramboagent »
Bitte mal um die Sprach Erweiterung (de)
ramboagent
    Windows 10 Edge
Al eine frage wäre es auch möglich das in der Erweiterung
Football Prediction League
Technischer Name: football/football
Beschreibung: Football Prediction League
mit einzubinden wäre super also so das wenn man Tippen will Spielscheine kaufen muss na halt wie beim LOTTO
