seacoast
Posts: 159 Joined: 28 Aug 2017, 19:58
Post
by seacoast » 09 May 2020, 23:34
dmzx wrote: 09 May 2020, 18:00
What is the conflict?
Yes confirmed it....when I disable recent topics the issue goes away.
Recent topics ON looks like this:
Recent topics OFF looks like this:
In addition, if I change the number of pages to 1 in recent topics, the problem goes away.
Posts: 348 Joined: 13 Dec 2014, 02:40
Post
by Solidjeuh » 11 May 2020, 13:09
I'm getting a console error in Firefox
This page uses the non-standard property "zoom". Consider using calc () in the relevant property values or use "transform" together with "transform-origin: 0 0".
In file: sweetalert2.all.min.js
Posts: 5123 Joined: 06 Apr 2014, 16:12
Post
by martin » 11 May 2020, 13:18
Use a real browser then
Post
by Solidjeuh » 11 May 2020, 20:40
martin wrote: 11 May 2020, 13:18
I do... Firefox
Posts: 1160 Joined: 14 Oct 2014, 19:01
Post
by Sniper_E » 13 May 2020, 01:35
I had a layout problem with the pagination also so I changed the
imageupload_index_body.html template.
I moved the pagination up in the header of the block and...
Moved the message from the <p> to a <div with class. (It needed some space around the message)
{% if IMAGEUPLOAD_USE_UPLOAD and IMAGEUPLOAD_INDEX_ENABLE and UCP_IMAGEUPLOAD_INDEX and loops.images|length %}
{% if IMAGEUPLOAD_IS_COLLAPSIBLE %}
<a class="category{% if S_IMAGEUPLOAD_HIDDEN %} hidden-category{% endif %} imageupload-category"></a>
{% endif %}
<div class="forabg">
<div class="inner">
<ul class="topiclist">
<li class="header">
<dl class="row-item">
<dt>{{ lang('IMAGEUPLOAD_UPLOADED_IMAGES') }}</dt>
<dd style="border: none; float: right">
{% if loops.pagination|length or IMAGEUPLOAD_PAG_IMAGES %}
<div class="pagination">
{{ IMAGEUPLOAD_PAG_IMAGES }}
{% if loops.pagination|length %}
{% INCLUDE 'pagination.html' %}
{% else %}
• {{ PAGE_NUMBER }}
{% endif %}
</div>
{% endif %}
</dd>
</dl>
<a href="{{ U_IMAGEUPLOAD_COLLAPSE_URL }}"
class="collapse-btn imageupload-collapse"
data-hidden="{{ S_IMAGEUPLOAD_HIDDEN }}"
data-ajax="phpbb_collapse"
data-overlay="true"
data-title-alt="{{ lang('IMAGEUPLOAD_COLLAPSIBLE_CATEGORIES_TITLE', ((not S_IMAGEUPLOAD_HIDDEN) * 1)) }}"
title="{{ lang('IMAGEUPLOAD_COLLAPSIBLE_CATEGORIES_TITLE', (S_IMAGEUPLOAD_HIDDEN * 1)) }}">
<i class="fa {% if S_IMAGEUPLOAD_HIDDEN %}fa-plus-square{% else %}fa-minus-square{% endif %}"></i>
</a>
{% endif %}
</li>
</ul>
<ul class="forums collapsible" style="max-height:210px; overflow-x:hidden; overflow-y:auto;">
<li class="row-items">
<dl>
<dt>
<fieldset class="fields1">
<div class="post bg2">{% if S_IMAGEUPLOAD_CHAT_INSERT %}{{ lang('IMAGEUPLOAD_INDEXPAGE_CHAT') }}{% else %}{{ lang('IMAGEUPLOAD_INDEXPAGE') }}{% endif %}</div>
<div class="panel upload_inner">
<div class="inner">
{% for images in loops.images %}
<div style="float:left; text-align: center;" class="upload_enabled">
<div class="imageupload_index-preview" onclick="imageuploadClick(this)">
<img class="imageupload_index" id="{{ images.ID }}" src="{{ images.IMAGEPATH }}" title="{{ images.FILENAME }}" alt="{{ images.WIDTH }} {{ lang('PIXEL') }} * {{ images.HEIGHT }} {{ lang('PIXEL') }} - {{ images.SIZE }}" />
</div>
<div class="imageupload-name">
{{ images.FILENAME }} <i onclick="insert_text(' [img]{{ images.IMAGEPATH }}[/img] ');" data-mchat-action="add" title="{{ lang('IMAGEUPLOAD_INSERT_MCHAT_IMAGE') }}" class="icon fa-arrow-circle-o-up fa-fw"></i>
{% else %}
{% endif %}
</div>
</div>
{% endfor %}
</div>
</div>
</fieldset>
</dt>
<dd style="border: none"> </dd>
</dl>
</li>
</ul>
</div>
</div>
{% endif %}
Post
by martin » 13 May 2020, 01:37
Now get 50 images uploaded your soon change ya mind.
also add collapse icon to it.
Post
by Sniper_E » 13 May 2020, 01:41
I don't understand that. The original template is back up on my site, see the awkward layout?
Post
by martin » 13 May 2020, 01:42
Original template the pagi was out side the box but it never got released as i moved it inside the frame.
Post
by martin » 13 May 2020, 02:48
Try this cators for a few images or lots.
{% endif %}
<div class="inner">
<li class="header">
</dl>
data-overlay="true"
</a>
{% endif %}
</li>
</ul>
<dl>
<dt>
{% else %}
• {{ PAGE_NUMBER }}
{% endif %}
</div>
{% endif %}
<p>{% if S_IMAGEUPLOAD_CHAT_INSERT %}{{ lang('IMAGEUPLOAD_INDEXPAGE_CHAT') }}{% else %}{{ lang('IMAGEUPLOAD_INDEXPAGE') }}{% endif %}</p>
<div class="inner">
</div>
{% else %}
{% endif %}
</div>
</div>
{% endfor %}
</div>
</div>
</fieldset>
</dt>
</dl>
</li>
</ul>
</div>
</div>
{% endif %}
Add this the the ext css file
p {
padding-top: 5px;
padding-left: 5px;
margin-bottom: 2px !important;
before
after
Posts: 310 Joined: 06 Apr 2015, 18:04
Post
by Scanialady » 14 May 2020, 20:52
seacoast wrote: 09 May 2020, 23:34
I confirm this problem, too. If there is more than one page on recent topics I get the pagination from there in image upload, too.
Post
by martin » 14 May 2020, 21:24
I suspect its posts_per_page as they both use the same setting in the acp.
Post
by Scanialady » 15 May 2020, 16:31
It would be nice if you could narrow down the problem and change the appropriate class. I personally would appreciate a correction.
seacoast
Post
by seacoast » 15 May 2020, 17:05
One minor suggestion....seems to me that having both the single image option AND the multiple image option is redundant because users can upload a single image in the multiple upload section. Just my thought.
Post
by martin » 15 May 2020, 17:13
Both options are better as i upload a single image and get the link right away and post it on another site.
Now if u used the multi for one image i then have to go to the index to see the image and then get the link.
Also there is now a new layout for images on the index long name images are shorted via the browser.
SAGreen
Posts: 15 Joined: 23 Feb 2020, 19:17
Post
by SAGreen » 08 Jun 2020, 18:26
I have a problem displaying images in UCP. When I click on it, a pop-up window will not appear, but an image with data will appear under the footer of the forum and the whole site will be scattered, see attached screen...
I also tried it on the default prosilver theme, but this error also manifested itself there. I would also like to ask where can I resize the HSIMG (URL-IMG link) to a certain width and height in px, and also if it is possible to delete images in UCP in bulk and not one by one. Thank you in advance for the info. Regards, Scott
Let's Go CommAndeR
