3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Youtube Videos Gallery
cristian
Re: Youtube Videos Gallery
Help me error
Any update if this is fixed from the OP ?
Your key is no good do it again.
FreakyReflex
Can it work if the key isn't good?
Cause it's working
Checked the key, and it's the same key i have on Google Api
Cause it's working
Yes but will make a debug like you got sit back and read the debug and see here
Make sure the api is also enabled the debug shows some thing wrong with the key.
FreakyReflex
So, i désinstalled Video Gallery and deleted everything.
Reinstalled Video Gallery, created a key just like on the video and still getting the error.
P.S.: I made a fresh installation of phpBB 3.1.5 as well.
What is wrong?
Update:
Video Gallery works fine now.
If someone has the issue like me, check the file "php.ini" and enable "openssl.so".
What is wrong?
Update:
Thanx for posting that.
Fast_Eddie
Would this be a file or funtion on the server? And when the key issue id fixed does the header error go away by it's self? Or do you need a fresh install of phpbb?. I walked away from this for awhile after banging my head on the desk to much. But ready to try and fix this againIf someone has the issue like me, check the file "php.ini" and enable "openssl.so".
OK: just generated another key (step by step with the video) plugged the key into the test board. And same error as before.
FreakyReflex
Connect to your Host Panel.
From there, you can edit your php.ini file.
Or ask your host for support (if free host).
Once i edited my php.ini file, the error code disapeared.
Fast_Eddie
Looks like I'm out of luck. Just got off the line with go-daddy support. They wont look at this for me because I'm trying to use '' 3rd party software ''
Thanks a lot go daddy
You guys do know you can edit your htaccess file to over ride the .php.ini file with your own file right ?
Note your host may complain to you about it tho.
Google
Fast_Eddie
Ok things are probably different per-hosting service. But how would i get to the php.ini file....and would i enable openssl.so ?Connect to your Host Panel. From there, you can edit your php.ini file.
BTW: Isn't ssl like a secure connection certificate thing like phpbb.com has?
FreakyReflex
Openssl.so activates the comunication between the servers "your host and youtube" and yes, it needs a secure connection.
When you're conected to your host panel:
- go to php settings
- there you will be able to edit the php.ini file.
