3.1.x Extensions Database 3.1 / 3.2[RC] Smilie Signs
Re: Smilie Signs
posting_editor_buttons_custom_tags_before.html is the problem in combination with posting buttons change to smiliesigns_posting_editor_buttons.html for test.
Re: Smilie Signs
Sniper_E wrote:I just looked in Solidjeuh's header codes and did not see the css for this loading with the other extension's css.
Maybe change the code in the event/overall_header_head_append.html to <!-- INCLUDECSS ../theme/smiliesigns.css -->
Changed.. see no difference
Re: Smilie Signs
Well guys the gasket in my mind just blew. I'm all confused on what to do now. :???:
Re: Smilie Signs
dmzx wrote:posting_editor_buttons_custom_tags_before.html is the problem in combination with posting buttons change to smiliesigns_posting_editor_buttons.html for test.
Bbcode disappears then
Re: Smilie Signs
No... maybe this code is fine.
	<select class="gensmall" name="smiliesign" onchange="bbfontstyle('[sign=' + this.form.smiliesign.options[this.form.smiliesign.selectedIndex].value + '', '[/sign]');this.form.smiliesign.selectedIndex = 0;" title="{L_BBCODE_SIGN_HELP}" style="height: 21px;">
I bet the conflict is in the includes/acp_manager.php file. I did copy that over from the posting buttons extension.
Re: Smilie Signs
Maybe ?
// Update existing BBCode
				$bbcode_id = $row_exists['bbcode_id'];
				$sql = 'UPDATE ' . BBCODES_TABLE . '
					SET ' . $this->db->sql_build_array('UPDATE', $bbcode_array) . '
					WHERE bbcode_id = ' . $bbcode_id;
				$this->db->sql_query($sql);
Re: Smilie Signs
Placed the smilies above the smilies
smiliesigns.zip
Re: Smilie Signs
Everything works like that :wall: :eusa_dance: :rolling:
Re: Smilie Signs
Maybe the onchange="bbfontstyle needs to be onchange="bbstyle() or something else.
Re: Smilie Signs
Renamed posting_editor_smilies_before.html to posting_editor_message_after.html
Now got room for more buttons :rolling:
Re: Smilie Signs
Seems to work perfect now.. :eusa_dance:
Re: Smilie Signs
Or put it above the buttons would be better, Name it posting_editor_buttons_before.html
I had it there once before. It doesn't look right in with the smilies.
Re: Smilie Signs
Bit of renaming works. also set the height to 18px so it fits better
Re: Smilie Signs
signs
Re: Smilie Signs
I think it would look even better under the smiley box
