Re: Youtube Videos Gallery
Grenader wrote: 13 Nov 2016, 14:27 When video deleted - i can't see anything. How i can reedit link to video without deleted?
For now you cannot edit the link of a video.
I will check this for future release.
Grenader
Post by Grenader »
An opportunity to throw video from category in category. Its be amazing too :thumbup: .
Gabriel
    Windows 7 Mozilla
Post by Gabriel »
Would be nice when you can work on the Title page. For now you only can delete files :/ . Want to edit files too :) Massimporter of video files would be geart stuff also.
Greetz fron germany.
Best Ext. for the board in my opinion. :thumbup:
nelflucifer
Post by nelflucifer »
Another translation into Russian, version 1.0.2
English Forums
playgoods
Post by playgoods »
I am trying to update from version 1.0.0 to 1.0.2
I disabled ext
Deleted data
Deleted folder in ext
Uploaded new version
But when I try to enable ext it gives me this error
Something went wrong during the request and an exception was thrown. The changes made before the error occurred were reversed to the best of our abilities, but you should check the board for errors.
A module already exists:
Kevicar
Post by Kevicar »
This is the same problem as for Ultimate Points with phpbb 3.1.10, you have to deliver the phpBB 3.1.9 files and correctly uninstall your module.
Then you update.
Ultimate Points Extension
:wink:
playgoods
Post by playgoods »
What do you mean deliver 3.1.9 files? I am already on 3.1.10
Kevicar
Post by Kevicar »
This is a problem with the phpbb version 3.1.10
It is necessary to deliver the phpbb 3.1.9 files (a backup), or wait for the phpbb version 3.1.11 which should fix this.
If you do not have more backup for 3.1.9 ... you put the original files that have changed and you delete the data in the database.
https://area51.phpbb.com/code-changes/3 ... pbb-avatar
:wink:
playgoods
Post by playgoods »
I upgraded from 3.1.6 to 3.1.10 so I have no backup of 3.1.9
Kevicar
Post by Kevicar »
You should give your version phpbb 3.1.6 ... then make the update phpbb 3.1.9 ! :thumbup:
...but not 3.1.10 that has too much problem :???:
playgoods
Post by playgoods »
So there is no way of this extension working on 3.1.10 ?
== EDIT ==
Posted in wrong topic .. sorry :rolling:
Kevicar
Post by Kevicar »
Yes it works during a first installation ... but phpbb 3.1.10 does not uninstall well the extensions ... the problem occurs during the updates ... and that for many other extensions.
Phpbb 3.1.10 to avoid!
Stay on phpbb 3.1.9 ... or wait for the next update. (Phpbb 3.1.11)
playgoods
    Windows XP Chrome
Post by playgoods »
I have removed the extension and deleted the data but it still will not work on 3.1.10
Can someone tell me how to install it on 3.1.10
playgoods wrote: 03 Jan 2017, 07:40 I have removed the extension and deleted the data but it still will not work on 3.1.10
I have it installed on 3.1.10 without a problem :eek:
