3.2 & 3.3 Extensions Database 3.1 / 3.2Mobile Device
Unantastbar
Re: Mobile Device
Post by Unantastbar »
It's not the best solution but it works.
{% if MOBILE_ENABLE && S_MOBILE_WELCOME && S_MOBILE_NAME && SCRIPT_NAME == "app/portal" %}
Re: Mobile Device
Remove the app/ its not needed.
Re: Mobile Device
Using that if statement may show on portal only.
Re: Mobile Device
My user told me that there is problem with user_agent
he e is with browser safari
this is his user agent: Mozilla/5.0 (iPhone; CPU iPhone OS 11_4 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/11.0 Mobile/15E148 Safari/604.1
this user used safari (facebook browser) browser
Re: Mobile Device
ivailo95 wrote: 11 Jul 2018, 11:04Mozilla/5.0 (iPhone; CPU iPhone OS 11_4 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/11.0 Mobile/15E148 Safari/604.1
That is 135 characters. User agent is setup for 255 characters. 'user_agent' => array('VCHAR:255', ''),
He should have been picked up using iPhone with that user agent info. You may have a different problem.
Not sure about safari (facebook browser) browser Maybe it is adding to the user agent string making it more than 255 characters.
Have him connect to here or at my test site with that browser and see if he has that problem.
Re: Mobile Device
The correct syntax for that if statement for portal would be written like this...
{% if MOBILE_ENABLE && S_MOBILE_WELCOME && S_MOBILE_NAME && (SCRIPT_NAME == "index" || SCRIPT_NAME == "app/portal") %}
Given that SCRIPT_NAME == "app/portal" works in the portal as Unantastbar stated.
Re: Mobile Device
So...what i need to edit to be correct?
Re: Mobile Device
This post was directed to you ivailo95
Sniper_E wrote: 12 Jul 2018, 21:28
The last post of mine was directed to earlier posts about the correct if statement syntax used for portals. Not for you ivailo95
Sniper_E wrote: 12 Jul 2018, 21:35 The correct syntax for that if statement for portal would be written like this...
ivailo95 have your guy try his safari (facebook browser) browser here at this site, martin's site or at my test site and see if he has that problem.
I would like to see what the issue is. Your explanation to the problem he is having does not add up.
Re: Mobile Device
The guy who told me about the problem tell me that here he can visit this site
Re: Mobile Device
This site is using an older version get him to visit mine https://www.martins-phpbb.com/forum/index.php mine is latest with a few added device's
Re: Mobile Device
martin wrote: 29 Jul 2018, 17:20 This site is using an older version get him to visit mine https://www.martins-phpbb.com/forum/index.php mine is latest with a few added device's
He said: Same error as yours board
Re: Mobile Device
ivailo95 wrote: 11 Jul 2018, 11:04 This is his user agent: Mozilla/5.0 (iPhone; CPU iPhone OS 11_4 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/11.0 Mobile/15E148 Safari/604.1
Do you understand this below that I already posted?
Sniper_E wrote: 12 Jul 2018, 21:28 That is 135 characters. User agent is setup for 255 characters. 'user_agent' => array('VCHAR:255', ''),
If he is getting the error that the data is too long for the user_agent field then that is not his user agent that is being detected.
You are providing the wrong information for his user agent. It has to be more than 255 characters to get that error.
You have three options...
1. Increase the 'user_agent' => array('VCHAR:255', ''), in the migration file and reinstall the extension.
2. Have him use a different browser other than that safari (facebook browser) browser. Whatever that is.
3. Disable the mobile device ext and delete the files off your server.
Re: Mobile Device
I have to admit i'v not had a problem with the ext i guess he needs to use a modern browser i'v not heard of the one he is using.
Re: Mobile Device
How long i need to set it up?
<?php
* @package phpBB Extension - Mobile Device
* @copyright (c) 2015 Sniper_E - http://www.sniper-e.com
* @copyright (c) 2015 dmzx - http://www.dmzx-web.net
* @copyright (c) 2015 martin - http://www.martins-phpbb.com
namespace sniper\mobiledevice\migrations;
class mobiledevice_schema extends \phpbb\db\migration\migration
	public function update_schema()
		return 	array(
			'add_columns' => array(
				$this->table_prefix . 'users' => array(
					'mobile_browser'      => array('UINT:1', 0),
					'device_name'         => array('VCHAR:30', null),
					'user_mobile_welcome' => array('BOOL', 1),
					'user_mobile_header'  => array('BOOL', 1),
					'user_mobile_self'    => array('BOOL', 1),
				$this->table_prefix . 'posts' => array(
					'post_device_title' => array('VCHAR:30', null),
			'add_tables'	=> array(
				$this->table_prefix . 'mobile_logs'	=> array(
					'COLUMNS' => array(
					'log_id'      => array('UINT', null, 'auto_increment'),
					'log_ip'      => array('VCHAR:15', ''),
					'log_time'    => array('INT:11', 0),
					'device_name' => array('VCHAR:30', ''),
					'user_name'   => array('VCHAR:30', ''),
					'PRIMARY_KEY' => 'log_id',
	public function revert_schema()
		return 	array(
			'drop_columns' => array(
					'mobile_browser',
					'device_name',
					'user_mobile_welcome',
					'user_mobile_header',
					'user_mobile_self',
					'post_device_title',
			'drop_tables' => array(
				$this->table_prefix . 'mobile_logs',
When i reinstal the extension he saw he can visit my board
wads24
Re: Mobile Device
Post by wads24 »
:wall: :wall: :wall: :wall:
I had this extension installed and working great. Not sure what I did, but when I went to install and enable again it said 405 not allowed, also will not let me delete data.
