camplife
Re: Youtube Videos Gallery
Post by camplife »
martin wrote: 01 Sep 2016, 13:46 You have another ext that is also using the same lang i'm sure i posted a fix (or dm) did.
Hmm...You're likely right. I have a lot of exts. runnin.
rickhaye
Post by rickhaye »
How do I make the gallery available to guests for viewing? I have set the permissions correctly but still only registered users are able to view. Thanks in advance.
camplife
Post by camplife »
rickhaye wrote: 16 Sep 2016, 12:10 How do I make the gallery available to guests for viewing? I have set the permissions correctly but still only registered users are able to view. Thanks in advance.
Should be in Group Permissions - advanced permissions
rickhaye
Post by rickhaye »
camplife wrote: 16 Sep 2016, 18:07
I gave "guests" all "yes" under group permission but it still doesn't show up for guests. Video gallery is available for registered users.
www.pinoysquadron.com
Maybe an existing extension conflicting. I have many extensions enabled.
berliner
Post by berliner »
When I open the Video button on the main page , the error message : [ phpBB Debug] PHP Warning : in file [ ROOT ] /ext/dmzx/youtubegallery/controller/youtubegallery.php on line 154 : file_get_contents ( https : //www.googleapis . ? com / youtube / v3 / videos id = & key = AIzaSyBp3WB2BZWovP8xU6BIPi9qkux8JcAvSN0 & type = video & part = snippet ) : failed to open stream : HTTP request failed ! HTTP / 1.0 403 Forbidden
[ PhpBB Debug] PHP Warning : in file [ ROOT ] /includes/functions.php on line 5312 : Can not modify header information - headers already sent by ( output started at [ ROOT ] /includes/functions.php:3925 )
Darkside2016
Post by Darkside2016 »
Is apache mod headers.load enabled ?
when you have acces to the sever you can do this by
a2enmod MODULNAME
a2enmod headers
as root
berliner wrote: 26 Sep 2016, 12:48 Hello
berliner
Post by berliner »
Is there another way? where can I find the apache mod header?
Hallo Darkside2016 du hast ne deutsche Flagge vielleicht kannst du mir mal auf deutsch weiterhelfen.
Ich habe bei Alfahosting mein Server das ist ein Linus oder?
Grenader
Post by Grenader »
Open overall_header_navigation_append.html:
find
<!-- IF not S_IS_BOT and S_USER_LOGGED_IN -->
Replace with
<!-- IF .video -->
rickhaye
Post by rickhaye »
Grenader wrote: 03 Oct 2016, 12:00
find
Replace with
<!-- IF .video -->
I made the changes and double checked guests permissions (set all to yes) yet guests are not able to view the gallery on the index page, only registered users. Any more ideas, thanks in advance.
Grenader
Post by Grenader »
[/quote]
[/quote]
I dont know. Its work for me. Maybe somebody will hint.
opoesiemen
Post by opoesiemen »
I have the same problem. The permissions are all put on "yes", but guests can't still not see the gallery. Does anyone has a solution? That would be great. Thanks in advance!
opoesiemen wrote: 17 Oct 2016, 09:26 I have the same problem. The permissions are all put on "yes", but guests can't still not see the gallery. Does anyone has a solution? That would be great. Thanks in advance!
Check the event folder in template.
Open all files and delete and S_USER_LOGGED_IN
Clear cache.
I have this when I use quick login on the youtube page
opoesiemen
dmzx wrote: 17 Oct 2016, 19:33
Clear cache.
Thanks DMZX! It works now! I can see the video's when I'm logged out.
Grenader
Post by Grenader »
When video deleted - i can't see anything. How i can reedit link to video without deleted?
