3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Who Visited This Topic
Tarantino
Re: Who Visited This Topic
Would be great to have an exclude option for forums. So it will only appear on the not excluded ones.
Will take this into accountTarantino wrote: 02 Mar 2023, 20:13 Would be great to have an exclude option for forums. So it will only appear on the not excluded ones.
German language files for 1.0.9 here. (Choose the file, right click - save under...)
pit
- New user
Thank U for this valuable extension.
My provider just upgraded mysql to V8 and we got following errors when accessing to a post (phpbb 3.3.10, php 8.2.8)
The solution found by the provider was to deactivate the SQL ONLY_FULL_GROUP_BY mode, as you wrote somewhere above.
Seems to be correct now.
Merci beaucoup.
Erreur générale
SQL ERROR [ mysqli ]
Expression #3 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'hva_forum.w.counter_user' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by [1055]
SQL
SELECT w.user_id, w.topic_id, w.counter_user, w.date, u.username, u.user_colour, u.user_id, u.user_avatar, u.user_avatar_type, u.user_avatar_height, u.user_avatar_width, u.user_type, SUM(w.counter_user) AS total FROM phpbb_whovisitedthistopic w, phpbb_users u WHERE w.topic_id = 4836 AND w.user_id = u.user_id AND w.user_id <> '65' GROUP BY w.user_id ORDER BY w.date DESC LIMIT 15Seems to be correct now.
Merci beaucoup.
Kinsman
I'm not sure why this is happening, we use the standard coloured usernames in PHPBB3, and this is how it displays?
Xxxbennyxxx
Is it possible to put who visited this topic under who is online in view_topic? I've looked myself, but I can't find an event
- Banned
Disable your extensions and then checkKinsman wrote: 09 Jan 2024, 01:24 I'm not sure why this is happening, we use the standard coloured usernames in PHPBB3, and this is how it displays?
Do you really understand the meaning of this extension?Xxxbennyxxx wrote: 22 Jan 2024, 20:29 Is it possible to put who visited this topic under who is online in view_topic? I've looked myself, but I can't find an event
Xxxbennyxxx
Of course, but I want it in view topic under the online block
SpIdErPiGgY
Rename viewtopic_body_footer_before.htmt to overall_footer_content_after.htmlXxxbennyxxx wrote: 22 Jan 2024, 20:29 Is it possible to put who visited this topic under who is online in view_topic? I've looked myself, but I can't find an event
And clear forum cache
✦ 🌐 phpBB Extensions in Dutch
✦ 💚 Support this project on Ko-fi
Xxxbennyxxx
Then it will not be shown in my block but below it. But it is solved, I created an event myselfOnnozel Manneke wrote: 23 Jan 2024, 06:23Rename viewtopic_body_footer_before.htmt to overall_footer_content_after.htmlXxxbennyxxx wrote: 22 Jan 2024, 20:29 Is it possible to put who visited this topic under who is online in view_topic? I've looked myself, but I can't find an event
viewtopic_body_online_list_after.html
Now just a little CSS and it's perfect.
- Banned
And what topics have these members read?
SpIdErPiGgY
The code is on the viewtopic page...
Xxxbennyxxx
Indeed, I created the event in viewtopic_body.html The extension still works as expected. But at least now it is displayed where it should be (for my style) in the block with the other statistics.
