3.1.x Extensions Database 3.1 / 3.2 ⇒ [RC] Smilie Signs
Puchahawa
Re: Smilie Signs
That page is pretty cool. Though I think Vinsent may cop an attitude about being mislabeled on his sign.
He doesn't seem like an unsure kind of guy.
Re: Smilie Signs
Hmmm that copy and paste just want work right all the time.
I was missing the write sign also. Now it's up to 113 sign choices.
I may need to add another 77 images to make it a cool 200.
But seriously... If anyone has a smilie you would like to see holding up a sign, I will create it add it.
Re: Smilie Signs
@ dmzx, I appreciate you fixing those files and looking at the html replacement to get {root_path} in there.
The bbcode html replacement want accept {ROOT_PATH} or {BOARD_URL} but it will accept a <script> before the sign codes.
Is there a way to define root_path in a script which we could insert into the smilie image url in the sign codes?
Otherwise IF anyone wanted this to work in custom pages, eg app.php/mchat,
they would have to hard code their site_url into the bbcode html replacement after install.
This ext is mainly written for the viewtopic page anyways so I guess it could just be ./ext/... done
Re: Smilie Signs
There was 1 event missing in the files you send me.Sniper_E wrote: 15 Oct 2016, 11:05 @ dmzx, I appreciate you fixing those files and looking at the html replacement to get {root_path} in there.
Can you PM me again your latest so we do not have to the code twice
Re: Smilie Signs
There was no event template missing from what I sent you. It was setup to work with your Posting Buttons and mChat only.dmzx wrote: 15 Oct 2016, 11:57There was 1 event missing in the files you send me.
Can you PM me again your latest so we do not have to the code twice![]()
But I was using event/posting_editor_posting_buttons_custom_tags_before.html template for your Posting Buttons.
I changed that event name in your Posting Buttons template to get everything working right.
You were looking for the missing event/posting_editor_buttons_custom_tags_before.html template in my files.
By using that event template in my ext, it will insert the normal button (class="button2") into your Posting Buttons... not the image.
Look, I have explained this to you a few times already and I still don't think you get it or you just don't agree.
Please understand this:
If I'm going to add a button in ABBC3, then I want to follow suit of that ext and add an image without a border, not a button.
Using the class="abbc3_button"
If I'm going to add a button in Posting Buttons, then I want to follow suit of that ext and add an image with a border, not a button.
Using the class="postingbuttons"
And for the normal prosilver buttons I want to add just the simple button.
Using the class="button2"
OK... NOW
Your Posting Buttons ext has a <!-- EVENT posting_editor_buttons_custom_tags_before --> in your template.
Once again...
I don't need help with my event templates. I was getting conflicts from the other event templates I was using while working with them... so I removed all the other event templates from my ext and got just those event templates working for Posting Buttons. Then I added the event templates back in I needed for ABBC3 and got the codes worked out for that ext... with no conflicts with the Posting Buttons event templates. Now all I have left is to put the event templates back in for the normal buttons and get those codes right for that without conflicting with the other event templates. This is what I had to do for the tables ext to get all those event templates working together. When I get all of the event templates I'm using worked out they will all work together like a string quartet.Wants this to be understood wrote:By using that event template in my ext, it will insert the normal button (class="button2") into your Posting Buttons... not the image.
The only thing I was needing help with was getting the html replacement to work with root_path for custom pages.
But I have giving up on that because I don't see any way to get around that except for putting your_site_url/ext/ in place of the ./ext/
Kinsman
Re: Smilie Signs
I have just installed the username bbcode from here, and trying to get it to display in abbc3. I used the same event as your smileys, but got username dropdown twice, and lost the smileys. I tried changing your event to after instead of before but it still doesn't display.
Frustrating, as I have room for both to display on the topline of abbc3, any thoughts?
Re: Smilie Signs
Try updating smilie signs extension to version 1.0.6 and see if that still happens.Kinsman wrote: 16 Oct 2016, 02:04 I have just installed the username bbcode from here, and trying to get it to display in abbc3. I used the same event as your smileys, but got username dropdown twice, and lost the smileys. I tried changing your event to after instead of before but it still doesn't display.
First post updated --> Smilie Signs 1.0.6
Kinsman
Re: Smilie Signs
I'll need to post in the right topic, even after install it wasn't working right in abbc3, it appeared, but wasn't doing anything, it also does not appear in the quick reply, so looks like a fair bit of work all round.
Kinsman
Re: Smilie Signs
Updated to 1.06, looks a bit odd in PBTech, and also missing from the quick reply?
http://www.junglewraiths.net/viewtopic.php?f=1&t=4765
Re: Smilie Signs
Yes I just installed smilie signs, abbc3 and username and the username ext did not show.
Renamed username's posting_editor_buttons_custom_tags_before.html
To vse_abbc3_posting_editor_buttons_custom_tags_before
Then the username ext showed up with the bbcodes but would not open and show users.
After disabling abbc3 the username showed up in posting and worked.
But it would not work in mChat's bbcodes. I have username version 0.0.1
Maybe I need to look for a more recent version.
Smilie Signs worked good in those tests. I'll have to check quick reply setup to add it there.
Kinsman
Re: Smilie Signs
Just for info I don't have username installed anymore, I removed it, removed smileysigns 1.05 and only reinstalled smileysigns 1.06.
It appears like the "post" of the sign is missing? And is also missing from quick reply.
Works good in mchat though, so I only need to fix the post, and quick reply.
Re: Smilie Signs
Just installed username 1.0.1 with smilie signs and abbc3 and everything worked in the posting page.
Username did not work in mchat with abbc3.
And again I had to renamed username's posting_editor_buttons_custom_tags_before.html
To vse_abbc3_posting_editor_buttons_custom_tags_before to get it to show.
Kinsman
Re: Smilie Signs
Ok
1: I do not have username installed
2: the posts are missing
3: its missing from quick reply.
4: the addition to mchat on the portal page fubars the entire layout of the homepage.
