3.2 & 3.3 Extensions Database 3.1 / 3.2Mobile Device
Re: Mobile Device
Don't be in denial... You may have a windows phone but it is most definitely an android. The Android 6.0.1 gives it away.
You need to add these lines in listener.php under the case (preg_match('/android/i',$user_agent)); line anywhere.
				else if (preg_match('/lumia 640/i',$user_agent))
					$status = $this->user->lang['Lumia 640 LTE'];
Then you will need an image put in the images/ directory. Lumia 640 LTE.png
I have found an existing image that looks close to a mobile device and copied it to a different mobile name. An option.
nucky91
Re: Mobile Device
Post by nucky91 »
I am not lying.. not android.. MICROSOFT NOT NOKIA :)
And.. not show the profile the mobile icon.. not working the /useragent/
Tarantino
Re: Mobile Device
Post by Tarantino »
Ofc it's windows... All Lumia are windows.
NOKIA have begun very recently a new road. With Nokia 3, 5, 6 and 8 all four already with Android. But all the others Nokia older smartphones was with Windows Mobile operating system.
Cheers
Re: Mobile Device
Ok I'm with you... It's not an Android. Clearly I didn't see Android.
I might have been mistaken and just thought I saw "Android 6.0.1" in your user agent from that image of yours.
I stand corrected.
Re: Mobile Device
I'l end this once and for all if any item is windozey based its crap :rolling: get ya self an android :tumbsyes:
I installed kodi on my s7 edge today.
nucky91
Re: Mobile Device
Post by nucky91 »
Ok thx the helps.. :) shit windows phone members..xD
Re: Mobile Device
Your suff still should show up Nucky. DM did an update on the codes not too long ago. I changed up the template and css. I was starting to add user selection to see your own images and was pulled off. I'll go back and see what I can do for an update.
Re: Mobile Device
Im on a galaxy s7 edge wonder what i show as ?
Yay i normaly show as a nexus lol
nucky91
Re: Mobile Device
Post by nucky91 »
It would be good, thx for the update because the latest update was 2015... :D
Re: Mobile Device
:???: not sure how but i got version 1.0.5 on mine just installed it from an old back up of files maybe a custom files from old site Ed ?
nucky91
Re: Mobile Device
Post by nucky91 »
Martin how finded the 1.0.5 version for this extension?
Re: Mobile Device
It's a version that was released to only a few ppl for testing a while back.
nucky91
Re: Mobile Device
Post by nucky91 »
Can you send it to me pls? : D It would be very important
Re: Mobile Device
Sorry no can do its private to a few of us also there is a good chance that Ed will be or is planning an update of this fine ext there for it will make this version redundant i only mentioned the 1.0.5 version as i thought it had been released but guess not.
nucky91
Re: Mobile Device
Post by nucky91 »
Ohh I undestand.. :/ I hope to release it in the days
