3.1 & 3.2 Extensions Database 3.1 / 3.2 ⇒ Topic Author
Re: Topic Author
Friends, I don't think my question is very complicated. Maybe someone will still answer it?
Re: Topic Author
You rename the event/viewtopic_body_avatar_after.html to event/viewtopic_body_avatar_before.htmlLEOPARD wrote: 23 Sep 2016, 20:39 How to make "Topic author" was displayed above the avatar and in the center?
That will place it above the avatar. If it's not center, edit the theme/topicauthor.css and add
.avatar-container {
text-align: center;
Re: Topic Author
No, just the "Topic author" to move. Avatar do not need to do at the center. How to do so?Sniper_E wrote: 24 Sep 2016, 03:12You rename the event/viewtopic_body_avatar_after.html to event/viewtopic_body_avatar_before.htmlLEOPARD wrote: 23 Sep 2016, 20:39 How to make "Topic author" was displayed above the avatar and in the center?
That will place it above the avatar. If it's not center, edit the theme/topicauthor.css and addNote: That will center the avatar also.Code: Select all
.avatar-container { text-align: center; }
Re: Topic Author
That will place it above the avatar. Then edit the theme/topicauthor.css
Replace margin: 10px 4px 10px 0; with margin: 10px auto;
OR
Replace margin: 10px 4px 10px 0; with margin: 10px 4px 10px 15px;
Play with the margins to get exactly what you want.
.topic-author {
display: inline-block;
OR
Re: Topic Author
Add config text color please
now i have a yellow button with white text on it
Q: Whats a hash and a root password?
A: hash gets you high, root password gives you god powers, combine the 2 and you are invincible.
Re: Topic Author
German Translation
Also go in Directory /ext/dmzx/topicauthor/adm/style and open acp_topicauthor_config.html and go to line 24.
There is this
Change there the maxlenght to 15.
Then go to general and delete cache. Now you can write in ACP on your Board Themen Autor.
Default is maxlenght 10.
There is this
<dd><input name="topicauthor_text_field" type="text" id="topicauthor_text_field" class="inputbox autowidth" value="{TOPICAUTHOR_TEXT_FIELD}" maxlength="10" /></dd>
Re: Topic Author
@Musiker15:
[ Post made via Android ]remoss wrote: 17 Aug 2016, 09:40 In ACP the max length of Authors text is limited to 10 characters, so "Topic Starter" didn't fit. I changed it in acp_topicauthor_config.html to max 20 characters, so solved![]()
Re: Topic Author
Quote: Great extension!!!
Indeed
Indeed
Re: Topic Author
Hey DM, is there a way to make it so the "topic author" does NOT show up in the first post? Kind of a duplicate expression.
Re: Topic Author
yes you can try thisPuchahawa wrote: 10 Mar 2017, 23:29 Hey DM, is there a way to make it so the "topic author" does NOT show up in the first post? Kind of a duplicate expression.![]()
Open ext\dmzx\topicauthor\event\listener.php
public function viewtopic_modify_post_row($event)
$post_row = $event['post_row'];
$post_row = array_merge($post_row, array(
'TOPICAUTHOR_COLOUR' => $this->config['topicauthor_colour_field'],
'TOPICAUTHOR_TEXT' => $this->config['topicauthor_text_field'],
'TOPICAUTHOR_TEXT_COLOUR' => $this->config['topicauthor_text_colour_field'],
'TOPICAUTHOR_ENABLED' => $this->config['topicauthor_enable'] ? true : false,
$event['post_row'] = $post_row;
$topic_data = $event['topic_data'];
$row = $event['row'];
'TOPICAUTHOR_ENABLED' => !$post_row['S_FIRST_POST'] = $topic_data['topic_first_post_id'] == $row['post_id'] ? true : false,
Re: Topic Author
Love this ext, however still using these edits in new 1.0.4, when inspected on mobile I would much rather have it aligned left. Also, when not the topic author, inject a simple <br> to keep more vertically aligned on mobile, within the html. I suppose the <br> could be done also with a class="responsive-show" if needed on other themes.
topicauthor.css
view_body_avatar_after.html
If anyone prefers the same thing.
topicauthor.css
.topic-author {
margin: 5px 4px 5px 0;
padding: 2px 5px;
background-image: url("./images/highlight.png")!important;
border: 1px solid rgba(0, 0, 0, 0.27)!important;
border-radius: 3px;
-moz-border-radius: 3px;
-webkit-border-radius: 3px;
-webkit-box-shadow: 0px 1px 4px rgba(0,0,0,0.3), inset 0px 1px 0px rgba(255,255,255,0.13);
-moz-box-shadow: 0px 1px 4px rgba(0,0,0,0.3), inset 0px 1px 0px rgba(255,255,255,0.13);
-moz-background-clip: padding;
text-shadow: 0px -1px 0px rgba(0, 0, 0, 0.2)!important;
font-size: 9px;
font-weight: bold;
background-repeat: repeat-x;
text-transform: capitalize;
<!-- IF postrow.TOPICAUTHOR_ENABLED -->
</div><div>
<!-- IF postrow.S_TOPIC_POSTER -->
<div class="topic-author" style="background: #{postrow.TOPICAUTHOR_COLOUR}; color: #{postrow.TOPICAUTHOR_TEXT_COLOUR};">{postrow.TOPICAUTHOR_TEXT}</div>
<!-- ELSE -->
<br />
Check out phpBB contributions & extension downloads.
