Re: Image Upload
Strange its working fine on 4 other sites.
Puchahawa
Re: Image Upload
Post by Puchahawa »
I don't remember, are there permissions involved with this? If so what type?
Re: Image Upload
Extensions tab enable it also groups permissions to be able to use it if its off your see the button but get a message saying its off.
You can pm me a link and test account with acp access if you want.
Puchahawa
Re: Image Upload
Post by Puchahawa »
Would like that but it's localhost. :wall: Only thing I can think of is, it may be another ext in conflict some how. Disabling the few that affect the posting page somehow. Will let you know what I find if anything. :smile:
EDIT: Figured it out. I've been testing a few different extensions and there is one called (DEV) phpBB Wall Extension - msaulohenrique/wall -
Wall Extension for phpBB 3.1 & 3.2 Version: 1.0.0
It adds additional functionality to members profiles, like adding images and music. Must be something in his submit code that causes this one to not function correctly.
Looked at the lightbox also and it plays nicely with that one. :eyes2: :rolling:
Re: Image Upload
I just tested on 3.1 and 3,2 running php7 also installed the reset posting buttons ext and all worked perfect and yes it plays with lightbox nce.
kaspir
Re: Image Upload
Post by kaspir »
Nice ext!
This would be great instead for image links, ex: http://yourdomain.com/example/image.gif
martin wrote: 02 Feb 2017, 23:00 Your like the next version then lol
:beers:
Check out phpBB contributions & extension downloads. :P
Re: Image Upload
Re: Image Upload
kaspir
Re: Image Upload
Post by kaspir »
So not 1.0.1 then, the next one after? :(
I can wait for it! Too much on my plate already, but this is a great ext, ppl can turn there sites into img hosts! (not for me, but still awesome!)
I thought about using more for replacing another image upload for within posts. :cheers:
Re: Image Upload
Re: Image Upload
The German language pack (not contained in v1.0.2).
No difference between v.101 and v1.0.2 in language files.
Puchahawa
Re: Image Upload
Post by Puchahawa »
Hi Dmzx. Was wondering of it would be possible to sort the uploaded by column alphabetically. Was thinking that if there was a reason you needed/wanted to remove all the images from one member that it would be easier if they were all together. Especially if this was used for awhile and there were many hundreds of images.
RTI kartname
Re: Image Upload
Post by RTI kartname »
The downloaded file is corrupted :wink:
Re: Image Upload
RTI kartname wrote: 05 Feb 2017, 18:35 The downloaded file is corrupted :wink:
Fixed thanks for reporting :thumbup:
RTI kartname
Re: Image Upload
:tumbsyes: :wave:
