3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Ultimate Points Extension
Re: Ultimate Points Extension
Good Evening
I really love the idea of this extension, however am having some difficulty installing it. Any help would be very much appreciated.
I first installed 1.1.6 from GitHub, but couldn't get it working as the Points Settings menu was broken with 500 internal server error (issue posted on GitHub with error logs)
Now ive disabled, and deleted that and when I install 1.1.8 version I cant even activate it, I get a 500 internal error upon activation.
Has anyone else had this issue?
I'm running 3.2.2 PHPBB.
Thanks in advance,
Thanks in advance,
- Donator
Same here on phpBB 3.2.2 and 3.2.3 RC.1
Seems to be an issue with migrator.php
will install and check it.Solidjeuh wrote: 01 May 2018, 17:49 Same here on phpBB 3.2.2 and 3.2.3 RC.1
First post download works ok on my test forum.Solidjeuh wrote: 01 May 2018, 17:49 Same here on phpBB 3.2.2 and 3.2.3 RC.1
What version of php are you using?
- Donator
At the moment PHP 7.0.28
The same problems on 2 forums on different servers.
viewtopic.php?f=62&t=3083&p=19788#p19788
I never installed ultimate points or any other mod on this database before so it cannot be that. I also know how to remove things from the database myself. I have no clue why this doesn't work but on a fresh install it just gives that error.Scanialady wrote: 26 Apr 2018, 21:30seems you have let overs from an old MOD in your database. Search on phpBB.com how to remove it (STK)Code: Select all
[internal function]: phpbb\db\migration\tool\module->remove('acp', 'ACP_CAT_DOT_MOD...',
Can we have the French version?
The speed and reliability of your website in WANTETE WEB HOSTING
Your website and forum at 0.90 € /month without advertising or conditions.
I cannot translate it to French..
- Translators
Dmzx you have the translation here viewtopic.php?f=75&t=2416&p=19300#p19300
Hello Midway,
Thank you for the translation, unfortunately I can not access it
I have problem with ultimate points installing on phpbb3, whenever i try to enable it, it says
what do you think do i need to do to fix it?
Fatal error: Uncaught exception 'phpbb\module\exception\module_exception' with message 'CANNOT_REMOVE_MODULE' in /home/www/paidpost.nabaza.com/phpbb/module/module_manager.php:448 Stack trace: #0 /home/www/paidpost.nabaza.com/phpbb/db/migration/tool/module.php(420): phpbb\module\module_manager->delete_module(230, 'acp') #1 [internal function]: phpbb\db\migration\tool\module->remove('acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #2 /home/www/paidpost.nabaza.com/phpbb/db/migration/tool/module.php(454): call_user_func_array(Array, Array) #3 [internal function]: phpbb\db\migration\tool\module->reverse('add', 'acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #4 /home/www/paidpost.nabaza.com/phpbb/db/migrator.php(714): call_user_func_array(Array, Array) #5 /home/www/paidpost.nabaza.com/phpbb/db/migrator.php(683): phpbb\db\migrator->run_step(Array, false, true) #6 /home/www/paidpost.nabaza.com/phpbb/db/migrator.php(436): phpbb\db\migrator->process_data_step(Array, Array) #7 /home/www/paidpost.nabaza.com/phpbb/db/migrator.php(288): phpbb\db\ in /home/www/paidpost.nabaza.com/phpbb/module/module_manager.php on line 448
500 error also here.. version 3.2.2
First post updated, fix for error in acp.
Thank you for the updates sir. i need to fresh install the extension but i cant. i still receive 500 error when attempting to delete data of the previous versions of ultimate points extension
PM me details and Admin account so I can check it for you.lenz wrote: 14 May 2018, 15:02 thank you for the updates sir. i need to fresh install the extension but i cant. i still receive 500 error when attempting to delete data of the previous versions of ultimate points extension
