3.1.x Extensions Database 3.1 / 3.2 ⇒ [RC] Tables bbCode
Puchahawa
Re: Tables bbCodes
Yeah, It works well as it is. If someone needs more than 6x10 they can add them manually. Nice work Sniper!
Only thing I can ask is will you please help me with the thead color issue in aeroblack.
Re: Tables bbCodes
I took the border out of the drop down class. Not all styles use borders so had to leave that open.
But it still should show a shadow and round corners in your different styles.
We'll have to check the mobile closer. I have to swipe the tables button to get the popup. Touchy on mobiles.
.tables:hover .table-selections {
display: inline-block;
position: absolute;
padding: 4px 6px;
margin-left: -50px;
margin-top: 20px;
-webkit-border-radius: 8px;
-o-border-radius: 8px;
-moz-border-radius: 8px;
border-radius: 8px;
box-shadow: 3px 3px 6px #999;
z-index: 999;
}We'll have to check the mobile closer. I have to swipe the tables button to get the popup. Touchy on mobiles.
Re: Tables bbCodes
Don't say thread color. th has a color. tr has a color. aeroblack may need it's own directory with some adjustments.Puchahawa wrote: 20 Sep 2016, 04:09Only thing I can ask is will you please help me with the thead color issue in aeroblack.![]()
What colors are you talking about? That transparent background you mean?
Add a border line in your copy of the tables.css .tables:hover .table-selections { border: 1px solid #444; }
proavia
Re: Tables bbCodes
Well, I hardly ever edit from my iPhone anyway - screen is too small and my old eyes aren't what they used to be.Sniper wrote:We'll have to check the mobile closer. I have to swipe the tables button to get the popup. Touchy on mobiles.
My old "Tab 2" I needed to swipe down to open drop downs (which didn't always work). On the newer "Tab A" it's different, but easier than swiping.
Icing on the cake would be to be able to have a choice of two border styles: The default and the "border-less". But I can certainly live without that option. I'm just glad I finally have a usable table extension!
Puchahawa
Re: Tables bbCodes
Yea, trying to get aeroblack to show a color in the table header like other styles do instead of mimicking the bg1,bg2 colors.
Re: Tables bbCodes
Try editing your table bbcode html replacement
And add a class in your tables/styles/aeroblack/theme/tables.css
If areoblack is your only style just edit the all/tables.css otherwise you need your own style dir
<div class="forumbg forumbg-table tbg {SIMPLETEXT}" style="width: {NUMBER}%"><div class="inner"><table class="table1">{TEXT}</table></div></div>Code: Select all
.tbg {
background-color: #DFDFDF !important;
Puchahawa
Re: Tables bbCodes
Ok. thanks again.
EDIT: Made the edits and it worked like a charm.
Re: Tables bbCodes
Cool! I will add that to the extension for the styles that need a little extra something something...
I can't tell you guys how much help your input has been.
I think we're just about there.
Re: Tables bbCodes
Changed Table Guidelines Layout.
event/posting_editor_buttons_before.htmlI removed the class="bg2" - not needed.
language/en/tables.phpI think you'll like the look of this much better.
<div id="table_guide" style="width: 550px;display: none">{L_TABLES_GUIDELINES}</div>language/en/tables.php
'TABLES_GUIDELINES' => '<hr><strong>Table Guidelines:</strong><br />[table=75 sets the width% of a table. Max width% of a table is 98%.<br />[th=20], [th=30], [th=50] sets the width% of each column. All [th=#%] need to equal 100%.<br />[table=75 tleft] will float the table left of the text. Use null, tleft, tright or tcenter in the table.<br />When using tcenter in the table, use the [center] bbcode around the Table Title for it to line up.<br /><hr><strong>Instructions:</strong><br />Click Preview after inserting your table codes. From your view, change the titles and text to suit your post. Adjust all the width% to balance out the look of your table. Preview and Submit.<hr>',-
Puchahawa
Re: Tables bbCodes
Just as a reference. This is the result. It makes it stand out more rather then blending into the background.Sniper_E wrote: 20 Sep 2016, 15:59Cool! I will add that to the extension for the styles that need a little extra something something...
I can't tell you guys how much help your input has been.I think we're just about there.
Puchahawa
Re: Tables bbCodes
Hmmmm made those table guidelines edits and have this as a result.
EDIT: just checked my second test board adding the edit for the table bg and not editing for the guide change and got the same result.
Started over with a fresh version of 2.0.4. added the tables html replacement it was ok. added the aero black style folder, with theme folder inside,with the tables.css file holding this edit for the bg
The background showed up fine on the tables. Went to reply to post and got the funky layout. Wonder why it didn't show up last night?
tbg {
}You do not have the required permissions to view the files attached to this post! Maybe your post count is too low.
Re: Tables bbCodes
I don't know, maybe your making the edits wrong. Here are the updated files.
Just replace your templates and language files.
Your image shows the old table selection buttons. We use images now. Update man. Maybe you should disable ext, delete data, delete tables/ files from your server, copy these new files over and enable ext.
Then add your background codes to the new tables.css stylesheet.
.tbg {
Puchahawa
Re: Tables bbCodes
I was editing the post just above yours when you posted.
The guideline edits are fine. The funky layout seems to be from the change for the background. Do I need more in that table.css file than that one entry? Don't know why the layout didn't mess up yesterday ??
Right now it looks like this
styles / aero black / theme / tables.css
all dir is still there as well.
Re: Tables bbCodes
No those buttons you are showing is the old stuff. Do a complete re-install.
You have copied old files over to that styles/areoblack/ dir.
And update your local copy with the new files and start again.
Puchahawa
Re: Tables bbCodes
Ok, here's strange. At least for me. I did the v2.0.4 fresh install and put the tables.css edit in the file in the all/theme folder. Not putting an aeroblack folder in at all and it's just fine.
I think I have a ghost in my pc.
Could just disabling the ext and replacing the files vs disable and delete data cause that issue?
