3.1.x Extensions Database 3.1 / 3.2 ⇒ [RC] Smilie Signs
Puchahawa
Re: Smilie Signs
Well, operator error struck again.
replaced the whole div with that bit instead of just that part.
Added the smilie and here we are.
Re: Smilie Signs
I found out... and you can see by your image that aero black's shadow is being cut off.
First line of HTML ReplacementSee, messing with you helps me find other flaws in my codes that need adjustment.
<div class="signs" style="text-align: center;padding: 6px 6px 0;display: inline-block;">-
Puchahawa
Re: Smilie Signs
Win / win.
Re: Smilie Signs
A few users have reported they can not see the images in the drop down because of their browser, or for whatever reason.
I've come up with another delivery system you guys may like.
Look for the smilie signs button image.
Kinsman
Re: Smilie Signs
Make it simple to revert, my smiley scroll boxes are fairly customised.
Puchahawa
Re: Smilie Signs
That looks cool Sniper. Looking forward to testing it.
Re: Smilie Signs
This is still in the works. Trying to make it work in the buttons extensions and in the chats. Difficult so far.
This is the base of it. Getting there...
Puchahawa
Re: Smilie Signs
Good progress.
I really like the option you've chosen of having the sign smilies on the right side.
I did a disable, delete data, enable.
This is what I'm seeing with prosilver. The button shows and works in prosilver. Choosing a sign from the list works correctly. and this is aero with the edited html repl. The button shows in aero but doesn't work. EDIT: corrected attachment.
You will want to know that these results are using the smilies scroll box ext.
Re: Smilie Signs
Thank you my man!
Damn, I didn't even think about updating the migration file for the html replacement in that dev package.
And I noticed later some of those images want show. I know what I did wrong creating those images.
I'll fix those. What images are those not showing in your post under the sign? All of them?
Is {ROOT_PATH} not working?
Yea it's cool having the smilies replaced with these sign smilies but it's tough making it all work together.
I may have to put these smilie selections in a popup instead. I'll keep working with it first before I go popup.
My only other choice is having them show where the Tables Guide instructions show but I don't like that idea at all.
<img src="{ROOT_PATH}ext/sniper/smiliesigns/images/icons/acute.gif" alt="" title="{L_ACUTE_TITLE}" />I may have to put these smilie selections in a popup instead. I'll keep working with it first before I go popup.
Puchahawa
Re: Smilie Signs
The three I have looked at are cheers, beer and bdaycandle. so I'm thinking you may be right and root path isn't working. will check some others to confirm.
Edit: tested 6 others and none of them show.
Re: Smilie Signs
Ed did you try ?
<img src="{BOARD_URL}/ext/sniper/smiliesigns/images/icons/acute.gif" alt="" title="{L_ACUTE_TITLE}" />-
Re: Smilie Signs
I noticed some of those icon images are missing. What happened to them? Weird because I had them in there.
Replacing {ROOT_PATH}ext/ with ./ext/ would work but not everywhere. I think I tried {BOARD_URL}/ext/ but I'll look again.
EDIT: {BOARD_URL} and {ROOT_PATH} both work in the template but not in the html replacement.
Re: Smilie Signs
EDIT: No no no the {ROOT_PATH}ext/ is used in the template for the smilie icon images to show. That works fine.
It's the ./ext/ code in the html replacement where the problem is at. Can we use {ROOT_PATH} or {BOARD_URL} in BBCodes?
./ext/ and ext/ work in the html replacement on my board but if you were in the apps/ directory with mchat it want work, I think.
Re: Smilie Signs
Having to hard code your sites url works in the html replacement but {BOARD_URL} and {ROOT_PATH} is not recognized.
<img src="http://sniper-e.com/ext/sniper/smiliesigns/images/sign_{SIMPLETEXT}.gif" alt="" />-
Re: Smilie Signs
Check your migration file it inserts:
<img src="./ext/sniper/smiliesigns/styles/all/theme/images/wood_pole_{SIMPLETEXT}.gif" alt="" style="margin-top: -1px;" />
