3.2 & 3.3 Extensions Database 3.2 / 3.3Ultimate Points Extension
xvi
Re: Ultimate Points Extension
Post by xvi »
Del. Sry.
chrisc93
Post by chrisc93 »
Hey,
I've installed this successfully on my forums however, the navigation menu isn't present at the top of the forums. I can't see any links for ultimate points. Can you help with this?
Cheers
seacoast
Post by seacoast »
Check permissions.
luca17000
Post by luca17000 »
Very good work !!
But it's u have the fr traduction.. in 3.1. it's similary ?
Sorry for my bad english... :oops:
Sorry it's good for me !
Midway
Post by Midway »
The translation french are in the forum and is not similare of the mod
EaglesTruth
Post by EaglesTruth »
As soon as I hit enable I get the following error
Fatal error: Uncaught phpbb\module\exception\module_exception: CANNOT_REMOVE_MODULE in /home/eagles7814/public_html/phpbb/module/module_manager.php:448 Stack trace: #0 /home/eagles7814/public_html/phpbb/db/migration/tool/module.php(420): phpbb\module\module_manager->delete_module(235, 'acp') #1 [internal function]: phpbb\db\migration\tool\module->remove('acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #2 /home/eagles7814/public_html/phpbb/db/migration/tool/module.php(454): call_user_func_array(Array, Array) #3 [internal function]: phpbb\db\migration\tool\module->reverse('add', 'acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #4 /home/eagles7814/public_html/phpbb/db/migrator.php(714): call_user_func_array(Array, Array) #5 /home/eagles7814/public_html/phpbb/db/migrator.php(683): phpbb\db\migrator->run_step(Array, false, true) #6 /home/eagles7814/public_html/phpbb/db/migrator.php(436): phpbb\db\migrator->process_data_step(Array, Array) #7 /home/eagles7814/public_html/phpbb/db/migrator.php(288): phpbb\db\migrator->try_apply('\\dmzx\\ulti in /home/eagles7814/public_html/phpbb/module/module_manager.php on line 448
I have a 3.2 phpbb board (fresh install) with mchat, pages, and application form mod which all work. I am also using the Milk paid theme and have gotten this extension to work on this theme with no issues on a previous site. I have no idea why this is not working. I cant even delete the data without getting the same error. I have to go to PhpMyAdmin and delete the stuff myself.
tnt
    Mac OS X iPhone
Post by tnt »
Hey! I recently installed this & now I'm getting error about phpbb_points_conf does not exist. Trying to disable the extension but I can't enter because of db error. Anyway to fix that? This extension f**ed my forum :(
EaglesTruth
Yeah nobody is addressing this. What I had to do was go into my PHPMYADMIN and delete the rows dealing with points in the ext table. Then purge the cache from the ACP and then delete the files from the server and everything from the points extension would be gone finally from the customize tab.
Hope this helps. But something does not work with this extension. Been waiting days for someone to let me know whats going on.
tnt
    Mac OS X iPhone
Post by tnt »
EaglesTruth wrote: 24 Apr 2018, 06:49 Yeah nobody is addressing this. What I had to do was go into my PHPMYADMIN and delete the rows dealing with points in the ext table. Then purge the cache from the ACP and then delete the files from the server and everything from the points extension would be gone finally from the customize tab.
The problem is that the table does not exist at phpmyadmin and I can't enter to my ACP to disable this. Can you specify more of how to do it?
tnt
    Mac OS X iPhone
Post by tnt »
Scanialady wrote: 24 Apr 2018, 13:07 Try to disable all extensions
https://www.phpbb.com/support/docs/en/3 ... s-at-once/
Tried the third method but sql "error not exist" still there and I can't disable it. Should I reinstall phpbb (deleting all files & uploading again except conf.php) without deleting the tables of phpmyadmin to keep my posts and users?
That would not work because this error seems to be in your database.
May be someone can help you if you tell us the exact error message
tnt
    Mac OS X iPhone
Post by tnt »
Scanialady wrote: 24 Apr 2018, 21:39 that would not work because this error seems to be in your database.
SQL ERROR [ mysql4 ]
Table 'admin_phpbb.phpbb_points_config' doesn't exist [1146]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
EDIT: Fixed, just replaced all default files & then enter to ACP. Well, thanks for wasting your time with me :)
EaglesTruth
Again I am getting this error when installing ultimate points...
seems you have let overs from an old MOD in your database. Search on phpBB.com how to remove it (STK)
