Extension official releasesphpbb [3.2.x] Extensions Database Releases • Header Link
Extension name: Header Link
Author: HiFiKabin
Extension description: Adds links at the top of the forum. You can add FA icons, colour the button, add shadow, control who has access to the link and more. Unused links do not appear as blank spaces as they are all aligned to the left (right in rtl languages) You can enter the HTML color you would like eg #0C93D7 or use the colour picker supplied. On Hover colour is also configurable.
Leaving the URL field empty on form submit deletes that button.
Compatible with my Sticky Bar Extension
The FA ICON codes can be found here and need to be entered as fa-file-pdf-o
On smaller screens the overflow buttons can be placed in a drop down menu.
Extension Version: 3.2.2
Language:
  • EN, FR
  • Additional languages: es, es_x_tu here
Supported Styles:
  • prosilver
  • Most prosilver based styles
Live Demo: HERE
  • Download the latest release and unzip it.
  • Upload the folder hifikabin to root/ext/ and enable it in the ACP
Support:
The contact us link at the bottom of this Board or This Topic
Extension version: 3.2.2
Download file: headerlink_3_2_2.zip
File size: 74.98 KiB
Source: [url]http://www.phpbb.com/community/viewtopic.php?p=15974845#p15974845
