3.1 & 3.2 Extensions Database 3.1 / 3.2phpBB Countdown
Re: phpBB Countdown
How can i revert to a normal text?
Re: phpBB Countdown
The font type is pulled in from: countdown/styles/prosilver/template/event/overall_header_head_append.html
<link href="https://fonts.googleapis.com/css?family=Montez" rel="stylesheet">
Edit: countdown/styles/prosilver/theme/countdown.css
/* .timecount #time {
	font-family: Montez;
Use those /* */ tags to comment out the use of that font.
Or just change that font name in both files to use the font you like.
You can select a font from All Availible Google Fonts
Re: phpBB Countdown
Is that correct?
.timecount {
	min-height: 26px;
	color: #AA0000;
	font-size: 22px;
	text-align: center;
	margin-top: 4px;
	padding-top: 4px;
./* .timecount #time {
.timecount .fireworks {
	background-image: url(images/ny-fireworks.gif);
	background-size: cover;
.count-time {
	display: inline-block;
	width: 26px;
	text-align: center;
span.cd-time {
	color: #105289;
@media (max-width: 600px) {
	.timecount img,
    span.cd-time.text {
		display: none;
	.timecount {
		font-size: 18px;
How can i fix this
see how min, days are up side
Re: phpBB Countdown
No that is not correct.
Change to
And the numbers, I've never seen that before.
.count-time {
	width: 26px;
	text-align: center;
I don't think it's loading that css. Fix the top part first then check those numbers.
Re: phpBB Countdown
I did but nothing changes
countdown.css
.timecount {
	min-height: 26px;
	color: #AA0000;
	font-size: 22px;
	text-align: center;
	margin-top: 4px;
	padding-top: 4px;
.count-time {
	width: 26px;
	text-align: center;
span.cd-time {
	color: #105289;
	.timecount img,
    span.cd-time.text {
		display: none;
	.timecount {
		font-size: 18px;
{% INCLUDECSS '@dmzx_countdown/countdown.css' %}
Re: phpBB Countdown
Try this in your countdown.css
.timecount {
	min-height: 26px;
	color: #AA0000;
	font-size: 15px;
	text-align: center;
	margin-top: 4px;
	padding-top: 4px;
.timecount #time {
	font-family: Verdana, Helvetica, Arial, sans-serif;
.count-time {
	width: 30px;
	text-align: center;
span.cd-time {
	color: #105289;
	.timecount img,
    span.cd-time.text {
		display: none;
	.timecount {
		font-size: 18px;
The font-size had to change for the regular fonts, and the width. I pulled those fonts out of prosilver's common.css
You have to adjust the font-size and the width to accommodate the font you choose to use.
.timecount { font-size: 15px; } and the .count-time { width: 30px; }
Re: phpBB Countdown
Is this ext avalible for higher version of php?
i update my board
i thought problem with number was from board vers.
Re: phpBB Countdown
ivailo95 wrote: 16 Feb 2025, 21:33 I thought problem with number was from board vers.
No, your problem was with the different font you were using and not adjusting the font-size and width for it like I stated above.
Don't bring new problems into your issue.
Re: phpBB Countdown
Sniper_E wrote: 16 Feb 2025, 21:39
it's too late..
Re: phpBB Countdown
PHPBB countdown doesnt appear in extension list to enable it
is avalible for 3.3.14 board vers?
    Mac OS X Firefox
Re: phpBB Countdown
ivailo95 wrote: 17 Feb 2025, 10:45 is avalible for 3.3.14 board vers?
Yes of course
After extracting the zip file you have to send the dmzx folder on the server, in the /ext directory, then you find the extension to activate in the ACP
phpBB: 3.3.15 | PHP: 8.4
Re: phpBB Countdown
ssl wrote: 17 Feb 2025, 11:01
Yes of course
I know that
i tried to enable it manually with this code
but doesnt work
https://palqk.eu/adm/index.php?sid=883a5207a7d936f4ff24e1f9508a433c&mode=main&action=enable_pre&ext_name=dmzx%2Fcountdown
Re: phpBB Countdown
This is indeed the way a lot of admins add an ext to their site. You said you know this.
ssl wrote: 17 Feb 2025, 11:01 After extracting the zip file you have to send the dmzx folder on the server, in the /ext directory, then you find the extension to activate in the ACP
What you probably don't know that if you have Extension Manager Plus extension installed,
then the disabled extensions will not show in the Manage extensions list, unless data has not been deleted.
You should install Upload extensions so you can upload any extension's .zip file and enable it. And be Done!
When you click Upload extensions select the Extensions Manager link.
In there it will show you all of your extensions including the ones disabled. You can enable or disable any extension there.
I have never heard of someone manually enabling an extension using File Manager. Stop with that nonsense. :guns:
You can also disable Extension Manager Plus extension and all of your disabled extensions will show in the Manage extensions list.
Re: phpBB Countdown
But i don't use Upload extensions or Extension Manager Plus on this board palqk.eu
This is my list of extensions i use
    Mac OS X Firefox
Re: phpBB Countdown
If the extension is sent to the right place on the server but it does not appear in the ACP to activate it, you must think about an incompatibility with another extension.
Try to disable your existing extensions, and check that you can enable phpBB Countdown. If you can enable it as the only extension, you must proceed by elimination to find the incompatible extension by reactivating them one by one.
EDIT
Take the opportunity to update your existing extensions.
