3.1 & 3.2 Extensions Database 3.1 / 3.2Newest Members
Newest Members
Extension Name: Newest Members
This extension shows the newest members instead of only one.
[travis]dmzx/Newest-Members[/travis]
Code update, validation version.
Added option to select value in ACP from 2 till 255 members.
Under Gerneral=>Board Features=>Set value for newest members.
  2. Unzip the downloaded release, and change the name of the folder to `newestmembers`.
  4. Copy the `newestmembers` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/newestmembers/composer.json
  6. Look for `Newest members` under the Disabled Extensions list, and click its `Enable` link.
Taka51
    Windows Vista Chrome
Re: Newest Members
Post by Taka51 »
Re Dmzx
translate French for the extension "Newest members"
Cordially
Newest Members 1.0.0 Translate French@Taka51_©Dmzx-web.net.zip
WebDvdBdR - Page d’index
Re: Newest Members
Taka51 wrote:Re Dmzx
Cordially
Added :thumbup:
Re: Newest Members
Translators please check the new files.
Re: Newest Members
Fast_Eddie
    Windows 10 Edge
Re: Newest Members
Post by Fast_Eddie »
Will this work with 3.3x ?
:beers: Retirement 2024!
Bruce Banner
Re: Newest Members
Post by Bruce Banner »
Fast_Eddie wrote: 2 years ago Will this work with 3.3x ?
I'd recommend trying to install it on a test forum.
Fast_Eddie
    Windows 10 Edge
Re: Newest Members
If i had one installed yep :)
Bruce Banner
Re: Newest Members
Fast_Eddie wrote: 2 years ago If i had one installed yep :)
You don't have somewhere to host one?
Re: Newest Members
I test all my stuff in my XAMPP local install. Setup the latest phpBB there.
You can select "Can reuse password" in acp then logout and register a few usernames (new users)
Then you can test this extension and any other before uploading it to your board.
But I do have to say I will test live on some things.
Fast_Eddie
    Windows 10 Edge
Re: Newest Members
Going to try it out on the slot car board. If it breaks it no big deal
I want to re-do it anyway.
Re: Newest Members
I test things on my localhost but we have all setup test sites on our live boards also.
Create a directory in the root of your forum named "test" and copy the latest phpBB files in there.
You will need a new database setup for it then visit https://yoursite.com/test/ and install it.
Fast_Eddie
    Windows 10 Edge
Re: Newest Members
Thanks Ed :)
I know ....I'm just being lazy at this point. Been away from things long enough to forget A LOT ! And I was NEVER at your guys level :eyes2: :rolling:
There is more. But it would be off topic for this post
