3.1.x Extensions Database 3.1 / 3.2Username Colour Changer
Extension Name: Username Colour Changer
Author: dmzx special thanks to martin and RMcGirr83
This extension allows users to change there username colour.
[travis]dmzx/Username-Colour-Changer[/travis]
Add permission for higher phpBB versions
Add option in ACP that allow Admin to change the colour of member.
Change a users colour everywhere
Set permission for the group that can change there user colour
ACP option
  2. Unzip the downloaded release, and change the name of the folder to `usernamecolourchanger`.
  4. Copy the `usernamecolourchanger` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/usernamecolourchanger/composer.json
  6. Look for `Username Colour Changer` under the Disabled Extensions list, and click its `Enable` link.
Re: Username Colour Changer
Version update
kencerda
Post by kencerda »
This is probably a silly question but where do I set the permission for the group that can change there user colour? It works great for admin users but I cant seem to find where to set it for registered users. I have looked at all group permissions I can find but I'm sure I'm missing something obvious.
kencerda wrote: 23 Feb 2016, 20:46 This is probably a silly question but where do I set the permission for the group that can change there user colour? It works great for admin users but I cant seem to find where to set it for registered users. I have looked at all group permissions I can find but I'm sure I'm missing something obvious.
Look under misc tab in group permissions
kencerda
Post by kencerda »
Dmzx, thanks so much for the quick response! I checked the misc tab but the permission wasn't there. I did a little more investigating and found that I didn't have the latest version. I followed the uninstall instructions, enabled the latest version and the permission is there now. I knew I was missing something obvious!
Thanks again for your help!
kencerda wrote: 23 Feb 2016, 21:26 dmzx, thanks so much for the quick response! I checked the misc tab but the permission wasn't there. I did a little more investigating and found that I didn't have the latest version. I followed the uninstall instructions, enabled the latest version and the permission is there now. I knew I was missing something obvious!
Thanks for the feedback and indeed latest version will show the permission.
killfrenzy
Post by killfrenzy »
Thanks for the update sir that admin can change color of username. Sir can you add sparkle extension for username. hehe
Visit my blog http://androidcribs.com Androidcribs.comAndroidcribs Image
zardos
Post by zardos »
Thanks for update. :thumbup:
The Good
Post by The Good »
Why when I change the color of one member !! so my color of my !!! change too with the same color but only in home page of forum view...
I keep my original color in post and profile.. but no in home page of my forum
The Good
Post by The Good »
No support ?
The Good wrote: 28 Mar 2016, 19:03no support ?
Yes but remember we are not always direct available.
The Good
Post by The Good »
dmzx wrote: 28 Mar 2016, 19:28
okey no problem I can wait.. but just don't forget me after x time
thanks and sorry!!
The Good wrote: 28 Mar 2016, 19:37
thanks and sorry!!
NP :wink:
I see what you mean need to take a closer look at it.
salazardeaguiar
    Windows 8.1 Firefox
Post by salazardeaguiar »
I love this extension and use from the beginning :)
Dmzx in the future have the ability to add new things? For example, the user option to leave the username italic, put background color, etc.?
I think it would be great :)
