3.1.x Extensions Database 3.1 / 3.2Button menu
7 given 1
Button menu
Extension Name: Button menu
This extension adds a menu under the header fully configurable via ACP.
  2. Unzip the downloaded release, and change the name of the folder to `buttonmenu`.
  4. Copy the `buttonmenu` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/buttonmenu/composer.json
  6. Look for `Button menu` under the Disabled Extensions list, and click its `Enable` link.
1 given 0
Re: Button menu
Be nice and il post an added for any theme.
:lol:
Demo of matching prosilver yourdomain.com - Index page
This version should detect your themes images and use them.
buttonmenu.zip
Files fixed due to conflict of search button css with the forum.
MOB
Re: Button menu
Post by MOB »
I'd like to report two little bugs with the Search Bar feature.
First:
If we disable the Search Bar in this Extension (not display the search bar in the menu), it will not return the Search box to the header of Prosilver.
It pretty much removes the search box on the header as soon as we install the extension. Only way to get the search box on the header, I have to uninstall the Button Menu extension.
Is there a workaround to this? I wonder?
Second:
It seems that I can't switch the Menu buttons to a different color. No matter what I select, it seems to only point to the Blue menu buttons. So if I want to use a different color button scheme, I have to replace the blue button scheme to what I really want. In other words, rename the black folder to the blue folder and etc.
1 given 0
Re: Button menu
MOB wrote:I'd like to report two little bugs with the Search Bar feature.
Second:
The colour changer does not know what other extensions you have installed for what you want to work you would have to add the images and css to the colour changers files.
Thinking about it you should not have the style colour changer as its donator only ?
Anuj Dhawan
    Ubuntu Firefox
Re: Button menu
Post by Anuj Dhawan »
martin wrote:The colour changer does not know what other extensions you have installed for what you want to work you would have to add the images and css to the colour changers files.
So to change the color of the menu, I'd need to have the color changer installed too?
PS.:Sorry to hijacking the thread but it talks what I was looking for.
moffacostanzo
Re: Button menu
Post by moffacostanzo »
this extension is not very responsive when look the site by smartphone
7 given 1
Re: Button menu
Yes this needs to be checked.
[ Post made via Samsung Galaxy S4 ] Image
Anders
Re: Button menu
Post by Anders »
I did found this and it works for now :wink:
buttonmenu.css
@media (max-width: 800px) { #menu { display: none; } }
Anuj Dhawan
Re: Button menu
It seems that I can't switch the Menu buttons to a different color. No matter what I select, it seems to only point to the Blue menu buttons. Any suggestion please?
tamarin
Re: Button menu
Post by tamarin »
First:
Second:
I've the same problem.
Here is the translation for Russian [ru] language. (s. attachment)
Anders
Re: Button menu
Post by Anders »
Try for example to set orange on the first row :wink:
tamarin
Re: Button menu
Post by tamarin »
Anders wrote:Try for example to set orange on the first row :wink:
Very very nice!
Thank you very much!
nelflucifer
Re: Button menu
Post by nelflucifer »
Hello everyone! As I promised, post the translation(s):
ru.zip
English Forums
moose5
Re: Button menu
Post by moose5 »
:tumbsyes:
Great extension!!!
And, yes, shoot me :guns: I used it on a live forum... :whistl:
iPhone visitors get this view with the blue bar all the way across and the rest of the screen only 1/2 wide. I have also replicated it with "Chrome - inspect elements" and changing the view to iPhone 5/6.
Forum is running prosilver on 3.1.9
Another problem not so important is the order buttons in the ACP don't seem to be doing anything for me. But that is easily fixable by delete/retype in the right order.
Thanks for any pointers what I could do to fix!
7 given 1
Re: Button menu
Also on the to do list to update again this extension.
