3.1.x Extensions Database 3.1 / 3.2Admin Colour Changer
Extension Name: Admin Colour Changer
This extension allows Admins to change there user colour in UCP.
downloadsystemcat?id=50
  2. Unzip the downloaded release, and change the name of the folder to `admincolourchanger`.
  4. Copy the `admincolourchanger` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/admincolourchanger/composer.json
  6. Look for `Admin Colour Changer` under the Disabled Extensions list, and click its `Enable` link.
    Windows 8 Chrome
Re: Admin Colour Changer
Note any topic made with 1 colour (red) then you change colour to (blue) the last post you made when red (on index) will remain red.
