3.3.x Extensions Database 3.2 / 3.3WebAuthn Passkey & Biometric Login
Extension Name: WebAuthn Passkey & Biometric LoginAuthor: dmzx
WebAuthn passkey and biometric quick login for phpBB
  2. Unzip the downloaded release, and change the name of the folder to `webauthn`.
  4. Copy the `webauthn` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/webauthn/composer.json
  6. Look for `WebAuthn Passkey & Biometric Login` under the Disabled Extensions list, and click its `Enable` link.
