Author: Galandas
Extension description: This extension will ensure that those entering for the first time at the forum, they will see a pop-up with a beautiful image that invites them to sign up, or you are already subscribed to login.
Features:
- Administration Control Panel
- Ability to change the background color with Color Picker integrated
- Ability to insert HTML code in the text area
- Ability to set the width and height of the frame
- Work with Cookies, close button does not show
- Global display in the forum
- Selecting whether to show the image, and change the default background color
- Languages: Italian - English
Tested on phpBB version: 3.3.14
Download file: Advanced_login_1.0.7.zip
File size: 42.23 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?p=16068703#p16068703
