3.3.x Extensions Database 3.2 / 3.3Notifications
Notifications
Extension Name: Notifications
Hides the notifications on the index, shows only when there is a notification/report or private message.
- First release
  2. Unzip the downloaded release, and change the name of the folder to `notifications`.
  4. Copy the `notifications` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/notifications/composer.json
  6. Look for `Notifications` under the Disabled Extensions list, and click its `Enable` link.
