3.2.x Extensions Database 3.2 / 3.3[3.3][DEV] User Statistics
HarveyWNvm LLC.
Post by HarveyWNvm LLC. »
Extension Name: Stat Block
Author: HarveyWNvm LLC.
Upcomibng
https://www.appunlockstoryplay.top/down ... s2.1.2.zip
Extension Download From GitHub:
https://github.com/HarveyWNvm/userstatistics2.1.2.zip
  2. Unzip the downloaded release, and change the name of the folder to `hrvy `.
  3. In the `ext` directory of your phpBB board, create a new directory named `hrvy` (if it does not already exist).
  4. Copy the ` file` folder to `/ext/hrvy/` if done correctly,
In the folder there are 3 languages ​​that are currently available.
Bulgarian
English
Russian
nFL-Cs.InFo Clock to Banner
The Good
Re: [3.3][DEV] User Statistics
Post by The Good »
Waiting to see screenshot...
Banned
Banned
The Good
Post by The Good »
ssl wrote: Jan 8th, '24, 01:04 The same ext here: https://www.phpbb.com/customise/db/exte ... tatistics/
MERCI :tumbsyes:
