Extension official releasesphpbb [3.3.x] Extensions Database Releases • Simple mentions
Extension name: Simple mentions
Author: Paul
Extension description: This extensions add support for mentioning a user by starting to type a @ in the posting field.
Once you select a user from the dropdown, the [mention] BBCode will be inserted and after submitting the post it will create a notification to that user.
Please note that starting with version 2.0 this extension require phpBB 3.3 and will not work with older versions
New in version 2.0
  • Support for mentioning groups. To enable this, you need to set the can mention groups permissions. Please note that for larger groups there is also a setting for limiting who can mention those (The amount can be set in the settings pane. The limitation for who can mention can be set via permissions).
  • BBCodes are no longer defined within the ACP, but is defined in code. Please note that changes done by hand to the old BBCode will no longer be respected. I do not provide support for changing the default BBCode, default text or adding a link.
    For backwards compatibility the old BBCode will keep working for old posts, but will no longer work for new or edited posts.
  • The amount of maximum users in the mention list is now configurable in the ACP.
  • This extension now requires PHP7.1 or higher, and phpBB 3.3 or higher. Older versions are no longer supported.
Extension version: 2.0.0
Tested on phpBB version: 3.3.10
Download file: paul999_mention_2.0.0.zip
File size: 101.02 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?p=15949801#p15949801
