3.3.x Extensions Database 3.2 / 3.3Workflow badge
Workflow badge
Extension Name: Workflow badge
This Extension will add a new BBcode for Github workflow tests.
Like this:
Workflow badge v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `workflowbadge`.
  4. Copy the `workflowbadge` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/workflowbadge/composer.json
  6. Look for `Workflow badge` under the Disabled Extensions list, and click its `Enable` link.
faroud
Re: Workflow badge
Post by faroud »
What does that extension mean?
what can you do with it?
regards :whistl:
Re: Workflow badge
faroud wrote: 19 Jul 2021, 12:10 what does that extension mean?
regards :whistl:
If you use github workflows you can add the badge to your forum.
It' s for testing purpose on Github, some coders like it :wink:
faroud
Re: Workflow badge
Post by faroud »
So nothing for me
anyway thanks for the info
:wink:
Re: Workflow badge
