Extension official releasesphpbb [3.3.x] Extensions Database Releases • Login Required
    Windows 10 Edge
Extension name: Login Required
Author: kasimi
Extension description: This extension allows you to forcefully redirect any non-logged in user to the login page with the possibility to add exceptions for specific routes to a whitelist.
This extension is based on the idea of the Force Login on index.php MOD for phpBB 3.0.
Changelog
  • v1.0.2 First CDB release
  • v1.0.3
  • v1.1.0
    • Compatibility with phpBB 3.2.x
    • Added option to define whitelisted pages as regular expressions
    • Increased event priority for better interoperability
    • Split ACP language files and removed all languages except en. Translators, please post your latest translations in the support section.
    • Removed version from the database config table
Extension version: 1.1.1
Download file: phpbb-ext-loginrequired-1.1.1.zip
File size: 14.51 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2564131&p=15569416#p15569416
