Forum Countdown extension display a countdown in your forums, just below the navbar. It can be configured in ACP.
- Unzip the downloaded release, and change the name of the folder to `Forum Countdown`.
- Copy the `forumcountdown` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/forumcountdown/composer.json - Navigate in the ACP to `Customise -> Manage extensions`
- Look for `Forum Countdown` under the Disabled Extensions list, and click its `Enable` link.
