3.2.x Extensions Database 3.2 / 3.3Coin index 3.2.x
Coin index 3.2.x
Extension Name: Coin index
Will display cryptocoins to your index. By https://www.worldcoinindex.com
dmzx/Coin-index
Coin index v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `coinindex`.
  4. Copy the `coinindex` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/coinindex/composer.json
  6. Look for `Coin index` under the Disabled Extensions list, and click its `Enable` link.
Re: Coin index 3.2.x
Thanx U very much. Very nice ext :tumbsyes:
Thanks. Tested on 3.3.7 and displays only Image
I inserted it:
and .yml check he says
Find tables.yml
parameters:
    tables.coinindex_table: %core.table_prefix%coinindex
Replace with
parameters:
    tables.coinindex_table: '%core.table_prefix%coinindex'
