3.1 & 3.2 Extensions Database 3.1 / 3.2Sidebar Menu
Sidebar Menu
Extension Name: Sidebar Menu
Extension Version: 2.0.4
Author: Sniper_E
Special thanks to: dmzx for help on making acp module work.
Extension Description: User controlled sidebars makes a perfect fit for every screen.
  1. Adds a sidebar menu to your site, replaces all header navbar links.
  2. Includes an extended ucp menu and sidebar ucp / board preferences.
  3. Selections for location of menus, global, index or off.
  4. Selections to show menus on left, right or both sides.
  5. Selections to set left sidebar, right sidebar and sidebar wrapper widths.
Version: 2.0.4
Tested on phpBB 3.2.2 but this should work on earlier versions of phpBB also, I have not tested that.
Snapshot:
Sniper wrote: New sidebar menus can use the event templates to add in a new sidebar menu on the right or left.
sniper_sidebarmenu_left.html and sniper_sidebarmenu_right.html
New links from other extensions can be adding in each of these 5 template events.
sniper_sidebarmenu_extensions.html
sniper_sidebarmenu_ucp_extensions.html
sniper_sidebarmenu_quick_links.html
sniper_sidebarmenu_staff_tools.html
sniper_sidebarmenu_user_links.html
Extension Download: sidebarmenu_2.0.4.zip
GitHub repository: GitHub/Sniper-E/Sidebar-Menu
Update:
  1. Seeing how this is dev... Disable ext, Delete data, Delete old files.
  2. Copy files to server ext/sniper/sidebarmenu/ directory.
  3. Navigate in the ACP to Customise -> Enable Sidebarmenu extension.
Install:
  2. Unzip contents from download, Copy files to server ext/sniper/sidebarmenu/ directory.
Uninstall:
  1. Navigate in the ACP to Customise -> Disable Submenu extension.
  2. To permanently uninstall, Delete Data, Delete the /ext/sniper/submenu folder.
Enjoy!
Re: Sidebar Menu
:thumbup: nice one!
