3.1 & 3.2 & 3.3 Extensions Database 3.1 / 3.2No Access
No Access
Extension Name: No Access
Author: dmzx & martin
The members who dont have access to a forum will see "No Access" on index and dont see the topic/posts numbers in that forum.
Based on this viewtopic.php?p=16601#p16601
dmzx/No-Access
- Update listener.
No Access v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `noaccess`.
  4. Copy the `noaccess` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/noaccess/composer.json
  6. Look for `No Access` under the Disabled Extensions list, and click its `Enable` link.
salazardeaguiar
Re: No Access
Post by salazardeaguiar »
Very cool, dmzx, thnx! :eusa_dance:
Hartenheer
Re: No Access
Post by Hartenheer »
Ik probeer dit op mijn testforum / I try this on my test forum
Maar begrijp niet hoe het verder ingesteld moet worden./ But do not understand how it should be further adjusted.
Wat moet ik nog meer doen om dit werkend te krijgen? / What else do I need to get this work?
Of werkt dit niet in 3.2? / Or does this not work in 3.2?
uruguayito
Re: No Access
Post by uruguayito »
From what I see that ext is for forums. Hides ALL the topics of that forum.
I'm looking for something for Themes..
Something like this ABD ext... https://www.phpbb.com/community/viewtop ... it=minimum ?
but for 3.2 :???:
I'm a latin american man.
Spanish is my language.
Beiley
Re: No Access
Post by Beiley »
martin wrote: 13 Oct 2017, 16:43
Beiley wrote: 13 Oct 2017, 16:13 That Har Vokse review is just what I've been looking for. We need a No Access extension on our board. Thanks Dmzx.
But have you got access ? :rolling:
That's just what I've been looking for. We need a No Access extension on our board. Thanks Dmzx.
Re: No Access
Beiley wrote: 13 Oct 2017, 16:13 That's just what I've been looking for. We need a No Access extension on our board. Thanks Dmzx.
Hartenheer
Re: No Access
Hartenheer wrote: 11 Jul 2017, 07:24 Ik probeer dit op mijn testforum / I try this on my test forum
up
found how to set it up further.
Fast_Eddie
Re: No Access
Post by Fast_Eddie »
Hey guys :)
I took a quick look at this and found no way to configure it. Does it just work off the permission system ?
:beers: Retirement 2024!
Re: No Access
Fast_Eddie wrote: 23 Nov 2017, 16:21 hey guys :)
yes it will work if perms are set in ACP, so set groups to nor read the forum and it will give the message.
Beba
    Mac OS X Safari
Re: No Access
Post by Beba »
I needed this! Thank you :tumbsyes:
Xxxbennyxxx
Re: No Access
Post by Xxxbennyxxx »
I know it will show in the last message field.
But is there a solution for mobile viewing?
