Extensions Database 3.2 / 3.3Tables 3.2.x
Tables 3.2.x
Extension Name: Tables
Author: Sniper_E
Extension Description: Inserts a table up to 7 columns, 10 rows in your post.
Completely style dependent to work in any dark or light style. Posting Buttons and ABBC3 ready!
Permissions added - 7th column added - New table generator - :mml: - Enjoy!
For phpbb 3.3
tables_2.1.3.zip
Extension Update:
Tables 2.1.4
Github: Github/Sniper-E/tables
Install:
  2. Unzip contents from download, Copy files to server ext/sniper/tables/ directory.
  3. Navigate in the ACP to Customise -> Enable tables extension.
Update:
  2. Disable tables extension, Delete data, Delete old version files from the server.
  3. Unzip contents from download, Copy new version files to the server.
  4. Navigate in the ACP to Customise -> Enable tables extension.
Uninstall:
  1. Navigate in the ACP to Customise -> Disable tables extension.
  2. To permanently uninstall, Delete Data, Delete the /ext/sniper/tables folder.
Re: Tables 3.2.x
First post updated to version 2.1.1
Added tables to Posting Buttons and ABBC3
lopoto
Re: Tables 3.2.x
Post by lopoto »
The selected attachment does not exist anymore. :coffee:
Re: Tables 3.2.x
I installed this extension because I wanted to translate it.
		'TABLE_GUIDELINES'			=> '<strong>Table Guidelines:</strong> [table=75,null] The number 75 sets the width% of a table. [table=75,tleft] The tleft floats the table left of the text. Use null, tleft, tright or tcenter. When using tcenter in the table, use [center] around the Table Title for it to line up. Max width% of table is 98%. [th=20,null], [th=30,null], [th=50,null] The numbers sets width% of each column. All [th=#% need to equal 100%. [td=null,1] The null is a class, use bg1, bg2, or any and the 1 sets the colspan of the [td]. If [td=null,2] is used you must remove one of the other [td=null,1] to make room for the 2 column. [tr=bg2] sets the class of the row. <br /><strong>Instructions:</strong> Click the Preview button after inserting your table codes in textarea. From your preview, edit all of the Title names and Text areas to suit your post. Adjust all the width% to balance out the look of your table, Preview and Submit.',
width%?? I don't understand for what is the %? Seems not to be a variable.
All [th=#% need to... isn't there not missing a ]?
Re: Tables 3.2.x
Max width% of table is 98%. What's wrong with that?
Should I have written that as...
Max width percent of table is 98 percent.
You can change your text any way you want it to read.
Re: Tables 3.2.x
Well, I was irritated. I have only seen this spelling as a variable. Now I understand.
Thank you.
German translation
Deutsche Übersetzung für FuGu ;)
Fugu
    Mac OS X Firefox
Re: Tables 3.2.x
Post by Fugu »
Is it possible to insert a hyphen between the columns in the rows?
So it looks like an Excel spreadsheet...
For example
Danke für die Übersetzung Scanialady
Re: Tables 3.2.x
I do not understand where to insert a hyphen.
I do not see a hyphen between columns in your example.
It looks interesting the way you posted that table.
What codes in your post did you use to get those results?
Or is that image what you want your table "to look like"
Fugu
    Mac OS X Firefox
Re: Tables 3.2.x
Post by Fugu »
Hi Sniper_E,
the table you see on the picture is a screenshot. Google translator made a mistake with "hyphen"... in german it's Trennstrich and i think correct in englsh it is *separating strip*. This is an very old modificatons of stoker with some code in the color.css
table.stoker    {
text-align: center;
font-size: 14px;
color: #444;
width: auto;
margin-left: auto;
margin-right: auto;
border: 0px;
border-collapse: collapse;
border-spacing: 10px;
table.stoker td.headline    {
background-color: #ce3c22;
color: #444;
padding: 2px;
text-align: center;
border-bottom: 2px #333 solid;
border-left: 1px #777 solid;
font-size: 18px;
font-weight: bold;
table.stoker td.headline:hover    {
background-image: url("./images/bg.png");
color: #444;
text-decoration: none;
table.stoker td    {
color: #444;
padding: 2px 10px 2px 10px;
text-align: center;
border: 1px #777 solid;
table.stoker td:hover    {
color: #ce3c22;
and there are of course bbcodes to use it. If you need the bbcodes i can post them too.
Again a pic to show what i miss...
Your extension is much more comfortable to use!
Re: Tables 3.2.x
Works
:mml:
Re: Tables 3.2.x
Fugu wrote: 9 years ago Is it possible to insert a hyphen between the columns in the rows?
For example
There is a way to use special classes that you add to the styles heel that will give you that look.
Old discussion:
[RC] Tables bbCode
I will test with this latest release and see what classes can give you what you want.
Galixte de EzCom
FRENCH translation of Tables extension
Post by Galixte de EzCom »
This is the FRENCH translation of Tables extension available on EzCom and on GitHub.
@Sniper i submitted you about a new PR on GitHub about the update to 2.1.1 version on your repository and adding the FRENCH translation.
Regards.
Communau EzCom
Image « Traductions d’extensions & styles pour phpBB 3.1.x & 3.2.x ».
vfrblue
Re: Tables 3.2.x
Post by vfrblue »
Hello, is it possible to extend the access rights to other groups?
Puchahawa
Re: Tables 3.2.x
Post by Puchahawa »
Yes. Will require a minor edit of a few of the ext files. Check out this post for the info.
vfrblue
Re: Tables 3.2.x
Post by vfrblue »
Okay, thanks, i'll try it
