3.2.x Extensions Database 3.2 / 3.3Did You Know 3.2.x
Did You Know 3.2.x
Extension Name: Did You Know 3.2.x
With this extension you can display texts in a small box at the top of the forum in a random order.
Code Update.
Did You Know 3.2.x v1.0.5
  2. Unzip the downloaded release, and change the name of the folder to `didyouknow`.
  4. Copy the `didyouknow` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/didyouknow/composer.json
  6. Look for `Did You Know` under the Disabled Extensions list, and click its `Enable` link.
Re: Did You Know 3.2.x
dmzx and martin Thanx U :tumbsyes:
Did You Know 3.2.x - Dutch translation.zip
I see no language changes between did you know 1.0.4 (3.1.x) and 1.0.4 (3.2x). So you can use the german language files from 3.1.x version.
Scanialady wrote: 06 Mar 2016, 10:51 I see no language changes between did you know 1.0.4 (3.1.x) and 1.0.4 (3.2x). So you can use the german language files from 3.1.x version.
Yes you can indeed.
moffacostanzo
Post by moffacostanzo »
i have this problem
Catchable fatal error: Object of class phpbb\template\twig\twig could not be converted to string in /web/htdocs/www.openresource.it/home/phpBB3/phpbb/extension/metadata_manager.php on line 131
moffacostanzo wrote: 09 Jan 2017, 16:59 hi
i have this problem
German language file [DE]
Neufoxet
Post by Neufoxet »
Please add a button "Next" to see more
Hartenheer
Post by Hartenheer »
Mijn talenkennis, of eerder gebrek aan talenkennis breekt weer op.
Krijg deze extensie niet aan de gang op mijn testforum
Test weetjes aangemaakt.
Op Language package op independent laten staan en geprobeerd op de Nederlandse taal pakket.
Maar er wordt niets getoond op het testforum.
https://www.aandeanderekantvanhetglasba ... /index.php
Wat doe ik fout?
Edit: opgelost
Bedankt Goldy
Hartenheer
Is het in de toekomst mogelijk om de tekst een kleur te geven?
Zodat hij meer opvalt?
Is it possible to color the text in the future?
So he notice more?
Hartenheer
Hartenheer wrote: 16 May 2017, 20:15 Is het in de toekomst mogelijk om de tekst een kleur te geven?
So he notice more?
@dmzx?
Neufoxet
Post by Neufoxet »
So he notice more?
Gebruikt de kleur bbcode hiervoor.
Hartenheer
dmzx wrote: 22 May 2017, 14:52
So he notice more?
Heb ik geprobeerd, in het voorbeeld had hij wel kleur. Op de pagina niet.
Ik heb het inmiddels opgelost met die
 [c]tekst[/c]
code van deze pagina. Nu valt het ook beter op
Charlie_M
Post by Charlie_M »
i've installed Version 1.0.5, but it doesn't show @ viewforum.
Option in personally board preferences "Show Did You Know on viewforum" is (as default) activated.
PHPBB-Version: 3.2.1 (Upgrade from 3.0)
Any ideas?
Best regards
