Posts: 6599 Joined: 13 Jan 2014, 21:45
Post
by dmzx » 01 Mar 2016, 11:40
Extension Name: Username Colour Changer
Author: dmzx special thanks to
martin and
RMcGirr83
This extension allows users to change there username colour.
Composer update
service.yml update
Add permission for higher phpBB versions
Add option in ACP that allow Admin to change the colour of member.
Set permission for the group that can change there user colour
ACP option
Download the latest release.
Unzip the downloaded release, and change the name of the folder to `usernamecolourchanger `.
In the `ext ` directory of your phpBB board, create a new directory named `dmzx ` (if it does not already exist).
Copy the `usernamecolourchanger ` folder to `/ext/dmzx/ ` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/usernamecolourchanger/composer.json
Look for `Username Colour Changer ` under the Disabled Extensions list, and click its `Enable ` link.
Posts: 356 Joined: 02 Nov 2014, 21:25
Post
by Jaantje » 06 Mar 2016, 10:49
dmzx ,
martin and
RMcGirr83 Thanx U
Username Colour Changer 3.2.x - Dutch translation.zip
Post
by dmzx » 13 Mar 2016, 11:54
Post
by Jaantje » 13 Mar 2016, 12:08
dmzx Thanx
Updated to version 1.0.2.
Post
by dmzx » 13 Mar 2016, 12:10
Jaantje wrote: 13 Mar 2016, 12:08
dmzx Thanx
Can you update your post with language file there is a change in ACP file.
Post
by Jaantje » 13 Mar 2016, 12:25
The Dutch translation for Username Colour Changer 3.2.x version 1.0.2.
Username Colour Changer 3.2.x V1.0.2. - Dutch translation.zip
Post
by dmzx » 13 Mar 2016, 12:26
Jaantje wrote: 13 Mar 2016, 12:25
zardos
Posts: 175 Joined: 26 Feb 2016, 23:20
Post
by zardos » 13 Mar 2016, 20:42
awr
Posts: 55 Joined: 13 Mar 2015, 08:50
Post
by awr » 14 Jan 2017, 15:10
Turkish language pack
tr.zip
infspirit
Posts: 25 Joined: 13 Sep 2015, 20:50
Post
by infspirit » 14 Jan 2017, 16:51
Spanish language pack
es.zip
Posts: 310 Joined: 06 Apr 2015, 18:04
Post
by Scanialady » 14 Jan 2017, 19:31
German language file. (corrected)
Scanialady on 18 Jun 2017, 09:54, edited 1 time in total.
miri4ever
Posts: 71 Joined: 22 Jan 2017, 15:39
Post
by miri4ever » 16 Jun 2017, 23:27
No German Files inside the German Translation here.
Funny
Posts: 126 Joined: 06 Mar 2017, 16:39
Post
by Funny » 16 Jun 2017, 23:42
In the folder
en simply edit the two php files
info_acp_usernamecolourchanger.php in German
'ACL_U_USERNAMECOLOURCHANGER_USE' => 'Kann Benutzername Farbe ändern',
'USER_COLOUR_TITLE' => 'Benutzername Farbe ändern',
'USER_COLOUR_EXPLAIN' => 'Kann die Farbe des Benutzernamens bearbeiten',
common.php: in German
'COLOUR' => 'Benutzername Farbe ändern',
That was it and good luck
mg Funny
miri4ever
Post
by miri4ever » 17 Jun 2017, 00:12
Thank you for quick help. Just searching ans updating evertthing I found and now I could finish this one as well.
Post
by Scanialady » 18 Jun 2017, 09:55
miri4ever wrote: 16 Jun 2017, 23:27
oops.... 6 downloads and nobody tells me
Sorry for the wrong archive. Corrected now
