3.2.x Extensions Database 3.2 / 3.3Topic Views 3.2.x
Topic Views 3.2.x
Extension Name: Topic Views 3.2.x
Displays Topic views in footer when viewing a topic.
  2. Unzip the downloaded release, and change the name of the folder to `topicviews`.
  4. Copy the `topicviews` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/topicviews/composer.json
  6. Look for `Topic Views` under the Disabled Extensions list, and click its `Enable` link.
Re: Topic Views 3.2.x
dmzx and martin Thanx U :tumbsyes:
infspirit
Post by infspirit »
Translate for spanish
Smayliks
Post by Smayliks »
Translate for russian (ru)
eunaumtenhoid
Post by eunaumtenhoid »
Brazilian Portuguese translation by eunaumtenhoid
https://github.com/phpBBTraducoes/topicviews
