3.1.x Extensions Database 3.1 / 3.2Nivo Slider
Nivo Slider
Extension Name: Nivo Slider
Adds Nivo Slider to your forum, max image size is 1170x320.
Up to 8 images and images need to be uploaded in ext/dmzx/nivoslider/images
Settings only for Admin and link in navbar header profile.
Nivo Slider v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `nivoslider`.
  4. Copy the `nivoslider` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/nivoslider/composer.json
  6. Look for `Nivo Slider` under the Disabled Extensions list, and click its `Enable` link.
erronblack
Re: Nivo Slider
Post by erronblack »
Is not working for me :( Tell me how to fix ?
Re: Nivo Slider
erronblack wrote: 03 Jan 2016, 20:15 Is not working for me :( Tell me how to fix ?
What style do you use and link to your board.
Re: Nivo Slider
erronblack wrote: 03 Jan 2016, 20:21 http://black-gaming.com/forum/
So what does not work? do you have more information?
erronblack
Re: Nivo Slider
SE Square left, based on prosilver .
samperals
Re: Nivo Slider
Post by samperals »
How to reduce the size of the slider please ?
Re: Nivo Slider
I reduced the size of the slider by reducing the image canvas size on height and increasing image canvas size on width.
The wider your image is... the smaller it will show in height on your page.
Original image
Thinner looking image
Edit: Hey I made two changes in the language file you may want to look at... (just these two lines were off)
	'SLIDER_BOX_ROWS_EXPLAIN'				=> 'Number of rows when using a box effect.<br>Default number is 4.',
	'SLIDER_PAUSE_ON_HOVER_EXPLAIN'			=> 'Set on to pause transition on hover.',
Re: Nivo Slider
I made a change too
nelflucifer
Re: Nivo Slider
Post by nelflucifer »
Interesting thing. As banner rotator you can use. And advertising something =) Thanks. :tumbsyes:
English Forums
samperals
Re: Nivo Slider
Post by samperals »
How to make Nivo Slider visible to the Guest ?
Re: Nivo Slider
My Nivo Slider is visible to guests. Isn't it setup this way by default.
samperals
Re: Nivo Slider
Post by samperals »
It is not visible to guests in my board ! what to do ?
Re: Nivo Slider
samperals wrote: 16 Jan 2016, 10:06 It is not visible to guests in my board ! what to do ?
There is no code for hiding it for guest in, PM me link of your board.
Bert
Re: Nivo Slider
Post by Bert »
I once made the translation into German language. Hope it helps a little.
If you find a mistake - which may keep him. :rolling:
de.zip
