3.1.x Extensions Database 3.1 / 3.2Badge Extension
9 given 1
Badge Extension
Extension Name: Badge Extension
Author:dmzx
This extension will add a badge bbCode selection box in posting template.
Can also make a Custom badge use SUBJECT-STATUS-COLOR within the [badge][/badge] tags and adjust to whatever you want.
Let me know if you need some default selections so I can add them to the extension.
[travis]dmzx/Badge-Extension[/travis]
Add class
Change code for symbols
  2. Unzip the downloaded release, and change the name of the folder to `badge`.
  4. Copy the `badge` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/badge/composer.json
  6. Look for `Badge Extension` under the Disabled Extensions list, and click its `Enable` link.
9 given 1
Re: Badge Extension
HeinrichP
Re: Badge Extension
Post by HeinrichP »
Nice, thanks very much :tumbsyes:
9 given 1
Re: Badge Extension
Re: Badge Extension
Thanx U very Much :tumbsyes: dmzx
Musiker15
Re: Badge Extension
Post by Musiker15 »
My Problem:
The badge bbCode selection box dont shown to me in the posting template.
I only can do create a custom badge with [badge][/badge].
In the ACP nothing to click about badge.
Do you have an idea who I can fix that? I have
I'm from Germany so my English is not the best...
________________________________________________________________
9 given 1
Re: Badge Extension
This is because the Advanced BBCode Box 3.1 is installed.
Rename the posting_editor_buttons_custom_tags_before.html to vse_abbc3_posting_editor_buttons_custom_tags_before.html
And clear cache.
Musiker15
Re: Badge Extension
Post by Musiker15 »
Were I do that? In which Folder?
9 given 1
Re: Badge Extension
Musiker15 wrote: 19 Oct 2016, 18:45 Were I do that? In which Folder?
\ext\dmzx\badge\styles\all\template\event\posting_editor_buttons_custom_tags_before.html
Musiker15
Re: Badge Extension
Post by Musiker15 »
Sorry that I ask again but where I clear cache?
9 given 1
Re: Badge Extension
Musiker15 wrote: 19 Oct 2016, 18:51 sorry that I ask again but where I clear cache?
NP :wink:
In ACP see image:
Re: Badge Extension
Tested on 3.3.7 and works. Thanks.
(Only - Version 1.0.0 - doesn't work well for me([ badge]Current version[ /badge]). The rest works nicely.
Hamidouki-dz
Re: Badge Extension
Post by Hamidouki-dz »
How to add others version ?
'VERSION'					=> 'version-1.0.0-FE7D37',
		'VERSION_TITLE'				=> 'Version 1.0.0',
		'VERSION_101'				=> 'version-1.0.1-FE7D37',
		'VERSION_107'				=> 'version-1.0.7-FE7D37',
		'VERSION_107_TITLE'			=> 'Version 1.0.7',
Hamidouki-dz
Re: Badge Extension
Hamidouki-dz wrote: 25 Dec 2022, 01:15 how to add others version ?
Can you help me for add others version !!
Banned
Banned
Re: Badge Extension
Open ./ext/dmzx/badge/styles/all/template/badge.html add:
		<option value="{L_VERSION_107}">{L_VERSION_107_TITLE}</option>
open ./ext/dmzx/badge/language/en add:
