3.1.x Extensions Database 3.1 / 3.2Move mini profile from right to left
Extension Name: Profile
Author: Martin
Extension Description: This will move the mini profile from right to left.
ext.zip
  2. Unzip the downloaded release.
  3. In the `ext` directory of your phpBB board, create a new directory named `martin` (if it does not already exist).
  4. Copy the `profile` folder to `/ext/martin/` if done correctly, you'll have the main extension class at (your forum root)/ext/martin/ /composer.json
  6. Look for `Profile` under the Disabled Extensions list, and click its `Enable` link.
uruguayito
Re: Move mini profile from right to left
Post by uruguayito »
Tky martin
a question: It is for all users by default or everyone can choose whether or not to move ?
I'm a latin american man.
Spanish is my language.
At the moment all users.
uruguayito
Do you plan to do so everyone can choose whether or not to move your profile ? That would be great
I was but no point as it's been done already.
profile_side_switcher-master.zip
Above file is installed on mine if you want to try it.
vla20071
Post by vla20071 »
There is an extension with the ability for users to choose which side to put the profile Tatiana5/profile_side_switcher · GitHub
Oooops... not done :D
Thats the ext i posted
I would remove all the other styles and rename prosilver to all :rolling:
vla20071
Post by vla20071 »
Delete my post... I didn't have time :)
uruguayito
martin wrote:I was but no point as it's been done already.
but, with this ext, you can move ALL the profiles.....
Robbie626
Post by Robbie626 »
This extension currently works with 3.2.2 :D
I will let you know if there are any problems with this extension for 3.2.x
dani50
Post by dani50 »
Can the extension be updated to 3.2.x , 3.3? Thx
What files one in first post or the other post ?
dani50
Post by dani50 »
martin wrote: 27 Jan 2020, 13:16 What files one in first post or the other post ?
First
Hensyr Wolf
    Ubuntu Firefox
Post by Hensyr Wolf »
Thanks very much for this extension, it works very well on phpbb 3.3
