3.1.x Extensions Database 3.1 / 3.2Switches
Switches
Extension Name: Switches
This extension will add some switches.
dmzx/Switches
None
3.3 version can be found here Switches
Switches v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `switches`.
  4. Copy the `switches` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/switches/composer.json
  6. Look for `Switches` under the Disabled Extensions list, and click its `Enable` link.
Re: Switches
Screenshot
Example of html code should look like
<!-- IF SWITCHES_ENABLE_FIRST -->
<div style="position: absolute; margin: -12px 0 0 -48px ">
    <img src="{ROOT_PATH}images/cornerhatbig.png" alt="Santa hat" />
</div>
note the <!-- IF SWITCHES_ENABLE_FIRST --> in the code and image ?
nelflucifer
Re: Switches
Post by nelflucifer »
Russian ru.zip
English Forums
Helios
Re: Switches
Post by Helios »
Italian language
it.zip
Re: Switches
Updated to work on 3.3
dmzx_switches_1_0_0.zip
{% if SWITCHES_ENABLE_FIRST %}
</div>
{% endif %}
or you can do it this way
<div id="hat1"></div>
{% endif %}
and put css in a css file
position: absolute;
margin: -12px 0 0 -48px;
background-image: url(images/cornerhatbig.png alt="Santa hat");
