killfrenzy
Re: Image Upload
Post by killfrenzy »
Help after update from v1.03 show this error
Something went wrong during the request and an exception was thrown. The changes made before the error occurred were reversed to the best of our abilities, but you should check the board for errors.
The config setting "imageupload_system_version" unexpectedly does not exist.
Return to the extension list
Thanks for response
Androidcribs.com
Androidcribs
Re: Image Upload
killfrenzy wrote: 08 Feb 2019, 17:06 Help after update from v1.03 show this error
Thanks for response
How did you update?
killfrenzy
Re: Image Upload
dmzx wrote: 08 Feb 2019, 17:31
Thanks for response
How did you update?
Disable the extension then enable the new version 1.06 without deleting data. Because I'm worried if my files will be deleted so that I didn't delete the data.
Re: Image Upload
Check your db if the imageupload_system_version is in the config.
Re: Image Upload
wads24
Re: Image Upload
Post by wads24 »
Getting the below error in the header of my page when going to a non existent folder. Should be just a 404 error, right?
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/8d3f1c68c5c160f92e8e46898886656e.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/1430cbadeae99ad42dbfde1b775821e4.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/cb6fb8503e20265faa02bf4c326098b0.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/8f5c84e97cdf309bfa1e9daf4927228b.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/736bff7b1c897633bcf1be58b312e241.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/405b3888d9bc018f6c71c4f794322eb1.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/252adfdc34fdd7386c68b70903f8dfc7.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/8a11a5e35ecb3bf5d04c63c2ede1db52.gif): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/fb562c1382ad120dfa325a564f54d51c.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/0da53ce7caae437406620189ca8bfc6c.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/8151a14ea547414d8aef130e9a0ce0b4.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/077051f28b6a2f5d0998b82f6a2ff919.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/3ff35474c9cc57c800d96d4e09e8b35b.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/0b1efe6aa90b19a1db50a9bf7886bf38.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/abb168c2839ca84d27846bd640ab924c.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/290a09aab4edfa7d104a1fa98f13a3f0.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/636f1ee4d1011ef93e7fc73a59ede3cf.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/252e7fb6c8bfd9a0414041082f9f2dd3.gif): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/8beb79b311ca7f358e9e6068360c8fde.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/f77ceb7e2a59679bd7aa6e44f80c6935.gif): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/b039ccac4e9c91167dfff110e3483844.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/c89b9a80c12ee97b619aed3048d9c3e9.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/ae81bb7bc43413130ee15e252be3c64e.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/ca4d6c335c3bc08e862c8626bbf003e4.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/572b2e5359ed5dfff5c5cf95f18a2550.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/a19e6965c339eef0d58e48403aa8fb6c.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/52d52f2ebbaba55f3c2e30182294903c.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/2d6d2f79cdb580d0043e8d34766e7569.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/e8f4202c58b2361db647424d185c8ad3.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/5c268a877cbadce927096d30d7af7961.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/bca940bc4a0038c33a7c526fc4f31e74.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/b430e3ca15c4519c6947d58cd7afa1af.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/998108df421d2c7dec0a4e23f2e91cc3.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/76330bb443136f4f49973132604ccf7d.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/90a951850e070021072467ce81f8d448.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/d837143c8ca32e3a05702784ebf73a13.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/30c697ae222076fa295171d56e871413.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/c7d22598f76adb646b1b745324f2fc4c.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/187dbba4b8685be5ded19f8288b7b614.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/5d52b59307529d8c344a33d68ddc8b50.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/ca7fccfa8f9f1b37a6ca0db32e037253.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/72fe85f72d8bcfb638e579e988e8840e.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/6399dab8108f2538f61121fac7f612ac.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/5b15ae86e743d7c31301c61084449311.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/7d90cf9a3d1c64d62e4395ef845b7735.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/d8304e202b8a85826d802f03d4ea8f69.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/c2c8c28f30e8ad6fb6f20cc3cae34664.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/480eeeaac015900a6cc04f78cbd97a0b.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/23b86e0b2fb7208edc737aa7e89f3a29.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/ea2df6064f36b0ee80e7ea6cc6ce5b60.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/d53f707f9670fc825c4081383b20e1a0.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/43a338e8d805f323d0fe27e3d881830b.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/348801f2854e4b186fb1bacdd7c72102.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/f649ef29a293df6fa24f4639f4bbfecd.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/74a6cab15d27a598a007445d6e5d0695.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/3a240084d2cbc16cd0132b83180fbb12.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/ab6d9b55678051ff4370e088a3ce0532.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/f8194711256db0e71d028c16f069380a.gif): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/eb47081b0c1dda3e50ce9f7cb9193e00.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/246922844d07e0f4bd9f7ffec2737911.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/e889d117b083989d812c57acb9f2f962.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/38dd226ea4d2c067e1622367fd6b2c87.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/f5f8c2d214af260ec5073f4ca1e34f74.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/ef759e2047c520ddc62e04018a66852b.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/95e62a8394df968c89a3b651fdca6873.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./../ext/dmzx/imageupload/files/3ef1b45af1c4cd55931e5f352d9c984a.jpg): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4564: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3314)
Re: Image Upload
Did you back up files folder first ? i would say you did not as the files are no longer on the server but they are still in the database hence the warnings if you have lost the uploaded images.
Go to acp and delete image one by one or unistall ext delete data then reinstall.
To update you need to back up the ext images folder first.
seacoast
not working on 3.2.1
Post by seacoast »
Having a problem with this. I upgraded from I think 1.0.4 and got errors. I deleted data, disabled and deleted data. Re-installed 1.0.7 and it made my board inaccessible. Got this instead:
Fatal error: Uncaught exception 'Symfony\Component\Routing\Exception\RouteNotFoundException' with message 'Unable to generate a URL for the named route "dmzx_imageupload_controller_upload" as such route does not exist.' in /home/nhgunfor/public_html/cache/production/url_generator.php:81 Stack trace: #0 /home/nhgunfor/public_html/phpbb/routing/router.php(168): phpbb_url_generator->generate('dmzx_imageuploa...', Array, 1) #1 /home/nhgunfor/public_html/phpbb/routing/helper.php(148): phpbb\routing\router->generate('dmzx_imageuploa...', Array, 1) #2 /home/nhgunfor/public_html/phpbb/controller/helper.php(114): phpbb\routing\helper->route('dmzx_imageuploa...', Array, true, false, 1) #3 /home/nhgunfor/public_html/ext/dmzx/imageupload/event/listener.php(178): phpbb\controller\helper->route('dmzx_imageuploa...') #4 [internal function]: dmzx\imageupload\event\listener->page_header(Object(phpbb\event\data), 'core.page_heade...', Object(phpbb\event\dispatcher)) #5 /home/nhgunfor/public_html/vendor/symfony/event-dispatcher/EventDispatc in /home/nhgunfor/public_html/cache/production/url_generator.php on line 81
Re: Image Upload
Try to delete folder production
seacoast
Re: Image Upload
Post by seacoast »
I deleted dmzx/imageupload before I reinstalled
Re: Image Upload
Feel free to pm me an admin account and board link if you fail to solve it.
Looks like your update failed.
seacoast
Re: Image Upload
Post by seacoast »
Reinstalled - this time when I click board is accessible but the IMG-UPLOAD link, this happens:
No route found for "GET /imageupload" (from "https://www.nhgunforum.com/index.php?si ... 98e86ed74a")
seacoast
Re: Image Upload
Post by seacoast »
I got it working. Just need to change colors in CSS. I have a dark style (Hexagon). I'm trying to change the white background of the link fields after the image is uploaded. Can't seem to find that in the CSS.
OR the font color.
Re: Image Upload
is there any possibility to upload image with drop?
i mean with droping image into image upload ext smth like imgyr :roll:
Beer
Re: Image Upload
Post by Beer »
Thanks for the extension! :tumbsyes:
I did a little translation into Russian.
I would add a description to the downloadable file - as is the Attachments in phpBB forum. :wink:
