3.1.x Extensions DatabaseButton menu
Button menu
Extension Name: Button menu
This extension adds a menu under the header fully configurable via ACP.
Button menu
  2. Unzip the downloaded release, and change the name of the folder to `buttonmenu`.
  4. Copy the `buttonmenu` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/buttonmenu/composer.json
  6. Look for `Button menu` under the Disabled Extensions list, and click its `Enable` link.
This topic has 80 replies
Register Logout
