3.2 & 3.3 Extensions DatabaseForum Icons
Magic user status: Online
Forum Icons
Extension Name: Forum Icons
Add forum icons, simply click on the icon to set the forum image.
Note: Upload all forum icons in images/forumicons
- Twig update.
Changed upload path to images/forumicons so when disable extension the links are not broken.
Add selected image
Forum Icons v1.0.3
Icon Package:
forum_icons_package.zip
  2. Unzip the downloaded release, and change the name of the folder to `forumicons`.
  4. Copy the `forumicons` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/forumicons/composer.json
  6. Look for `Forum Icons` under the Disabled Extensions list, and click its `Enable` link.
This topic has 55 replies
Register Logout
