Author: dmzx special thanks to martin based on the code of 4seven.
This extension shows Screen resolution in viewtopic.
Cookie based so logout and login again on your forum.
![Image](https://www.dmzx-web.net/upload/uploads/ae2d5420b2cb8525dddc24897cfba457.png)
downloadsystemcat?id=34
- Unzip the downloaded release, and change the name of the folder to `screenresolution`.
- Copy the `screenresolution` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/screenresolution/composer.json
- Navigate in the ACP to `Customise -> Manage extensions`
- Look for `Screen resolution in viewtopic` under the Disabled Extensions list, and click its `Enable` link.
