3.1.x Extensions Database 3.1 / 3.2Previous / Next topic button
Extension Name: Previous / Next topic button
Displays Previous / Next button in topic.
dmzx/Previous-Next-buttons
Work from version 3.1.0-RC5
Add after buttons top and bottom
download
  2. Unzip the downloaded release, and change the name of the folder to `prevnext`.
  4. Copy the `prevnext` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/prevnext/composer.json
  6. Look for `Previous / Next topic` under the Disabled Extensions list, and click its `Enable` link.
Re: Previous / Next topic button
New Version see Update version 1.0.1 · dmzx/Previous-Next-buttons@56afdc6 · GitHub for changes
New Version see Update Version 1.0.2 · dmzx/Previous-Next-buttons@6f8a38a · GitHub for changes
dmzx works perfectimo :tumbsyes:
As you can see, I have made the dutch translation :rolling:
cristian
    Windows XP Firefox
Post by cristian »
Thankyou man good code
can language Romanian Italian plisss ?
How and where can i change the text in the two buttons????
:wtf:
EDIT:
OK I fix it......
in root/language/de/viewtopic.php are the rows which i must change. :mml:
seacoast
Post by seacoast »
This may be a rhetorical questions since its in 3.1/Extensions...
But will this work with 3.2.1? If not, is there a plan to make it compatible?
Thank you.
If it works on 3.1 then there is a 99% chance it works on 3.2 and 3.2.1
seacoast
Post by seacoast »
It works great on 3.2.1
Thanks.
WhoIs
Post by WhoIs »
Hi, is this extension still being supported? I installed it with 3.3.0 and it works fine, but I was wondering if the code could be edited to disable loading of the extension if sees the screen size is less than 1200 pixels wide? When using a phpBB site on smart phones the buttons added by this extension get all jumbled up with the other navigation buttons when holding the screen vertically. Thanks.
It's for phpbb 3.1 and will need an update for 3.3 intime.
WhoIs
Post by WhoIs »
martin wrote: 23 Feb 2020, 02:32 It's for phpbb 3.1 and will need an update for 3.3 intime.
Thanks, but this is not a 3.3 issue. The extension runs fine in 3.3. It is an issue with mobile device screens below a certain screen width. The extension should detect that there is not enough space for the buttons and should not load on smaller mobile screens. This issue would happen on any version of phpBB.
By the way, there is a strange scrolling issue with this Forum when using FireFox. I am not able to scroll to the last post in a topic. The screen keeps scrolling up and down and doesn't stop. I had to switch to Chrome.
