3.1 & 3.2 Extensions Database 3.1 / 3.2Hide Birthdays
Hide Birthdays
Extension Name: Hide Birthdays
Display birthdays only when there is a birthday.
dmzx/Hidebirthdays
Code update, validation version.
None
Hide Birthdays v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `hidebirthdays`.
  4. Copy the `hidebirthdays` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/hidebirthdays/composer.json
  6. Look for `Hide Birthdays` under the Disabled Extensions list, and click its `Enable` link.
Nully
Re: Hide Birthdays
Post by Nully »
I installed extension, but it hides also upcoming birthdays (extension) :roll:
I'd like it hides Birthday > No birthday today, but I'd like also to see birthdays' dates for the future.
May be it's impossible :?:
Re: Hide Birthdays
Nully wrote:Hello,
Open rmcgirr83/upcomingbirthdays/styles/all/template/event
Change index_body_block_birthday_append.html into index_body_stat_blocks_after.html
Nully
Re: Hide Birthdays
Post by Nully »
yes! Next birthdays are showed :thumbup:
It is at the very bottom of board, after add Adsense, but I think it's ok.
Do you think I have to add you found solution in my post in phpbb.com?
Re: Hide Birthdays
Change the name to index_body_block_stats_append.html it shows then in the Statistics secction
Nully
Re: Hide Birthdays
Post by Nully »
Yes, now it's under statistics :thumbup:
It's better than under ads.
Re: Hide Birthdays
Nully wrote:Yes, now it's under statistics :thumbup:
Nully
Re: Hide Birthdays
Post by Nully »
:tumbsyes: :thankyou:
Re: Hide Birthdays
seacoast
Re: Hide Birthdays
Post by seacoast »
Will this run on 3.3.1?
